Old 11-01-2005, 11:44 PM   #1
ErikN
Rear Shock Mount
Wow, am I glad I found this place. Will it ever come in handy. I did a search and could not find the answer to my problem, so....
94 S10 Blazer 4x4. Rear shocks, lower mount. I pulled off the old shock, and unfortunatly left behind the lower shock bushing, seized onto the lower mount stud. It's kind of a big ball of rust, but is the stud attached permanently to the mount, or is it a carriage bolt that I could hammer out of the bushing and the mount. If not, what is the best way to get this bushing off the stud.
Thanks in advance.
Oh, yeah, I'm kind of a novice mechanic, without all the fancy tools, so an acetylene torch is unfortunatly not an option (especially this close to the gastank) )
ErikN is offline   Reply With Quote
Old 11-02-2005, 01:08 AM   #2
blazes9395
Newbie mod
blazes9395's Avatar
The stud is permanent, try cutting it off (the bushing) and sanding the bits and pieces off until its smooth. I myself would use the torch, clean it off, and throw on the new shock.
blazes9395 is offline   Reply With Quote
Old 11-02-2005, 11:45 AM   #3
Gabe25
Gabe25's Avatar
Re: Rear Shock Mount
Yea, I normally just torch it and with a big plier. Twist and pull. Comes right off.
1994 1st.Gen. S10 Blazer Tahoe
Aloha
Gabe
My Fleet
Gabe25 is offline   Reply With Quote
Old 11-02-2005, 02:13 PM   #4
ErikN
Thanks for the info guys.
What type of torch would work? Would just a propane plumbing torch be okay, or do I need a little more, like butane or acetylene.
Old 11-02-2005, 02:18 PM   #5
BlazerLT
AF -Advisor
BlazerLT's Avatar
No, you will need a cutting tourch to cut the old bolt off.
BlazerLT is offline   Reply With Quote
Old 11-02-2005, 03:17 PM   #6
ErikN
hmmm, okay, I thought Iwas just pulling the bushing off the stud though.
Old 11-02-2005, 03:23 PM   #7
Gabe25
Gabe25's Avatar
Re: Re: Rear Shock Mount
Just a propane torch will be OK. Heat the bushing up and with a large plier pull it off the stud.
Aloha
Gabe
My Fleet
The Following User Says Thank You to Gabe25 For This Useful Post:
exalteduser (02-26-2011)
Old 11-02-2005, 08:35 PM   #8
ErikN
Thanks everyone, but this didnt really work. I tried heating it, and then pliers/vice grips/pipe wrench after that. Didnt budge.
Plan B is to admit defeat and take it to a shop, unless anyone else has any ideas.
Old 11-02-2005, 09:10 PM   #9
Gabe25
Gabe25's Avatar
You can try and cut it off with a hack saw.
Aloha
Gabe
My Fleet
Old 11-02-2005, 09:17 PM   #10
ErikN
yeah, thats my next thought, although my friend has a small cutting wheel, might try that first.
Old 11-03-2005, 06:06 AM   #11
Rmbodie
Rmbodie's Avatar
Dremel tools work great fot this stuff . I cut a groove in opposite sides with a reinforced cutoff wheel and pryed the halves apart with a crowbar . Then dressed it up with a thread die . Rob
Rmbodie is offline   Reply With Quote
Old 11-05-2005, 07:10 PM   #12
ErikN
Hey, thanks for all the tips guys. The dremel wheel sliced the thing right offa there. The new shocks feel great.
So, anyone want a slightly used set of billsteins? Only about 200,000 miles on em.
