Old 11-02-2005, 12:45 PM   #1
JimofWare
bleeding brakes...
96 cav. is the car.
I broke the rear right brake line... I replaced the line but cold not get the bleeder open. I am looking to good (not the best) brakes to get this home so I can do it right at my place.
so I was planing on bleeding the brake from the line. this should work right? will I have to bleed all wheels or just the one with the broken line. what are the bleeders for on the master cyl.? I just need to get good peddel and good enough stopping power. please help.
Jim
JimofWare is offline   Reply With Quote
Old 11-02-2005, 01:12 PM   #2
maxwedge
A990 racer
Re: bleeding brakes...
If you lost a lot of fluid and drained the abs unit you will need to bleed all the brakes, you will not get a good pedal with your plan try and get a drift punch onto the area next to the w/c bleeder and give a couple of firm raps with a hammer, this will some times loosen the rust that is holding the bleeder.
maxwedge is online now   Reply With Quote
Old 11-02-2005, 01:26 PM   #3
JimofWare
the bleeder is broke flush... after I get it back home I am going to redo it all... just don't want to deal with the hubs to get the wheel cyl. out where it is at..
major PITA
