Go Back   Automotive Forums .com Car Chat > Chevrolet > Camaro | Firebird > Camaro Discussions
Old 10-29-2005, 01:03 PM   #1
Mndwg1
Send a message via Yahoo to Mndwg1
Talking 85 camaro innition problem
Seeing a new girl . she has a 85 camaro 2.8l mpfi. Car ran like crap (missing, backfiring,smelling ritch). I (being the man) decided to fix it. Bad idea. found old plugs to be in bad shape (carbon fouling & gapped at .062) so I replaced them with new plugs gapped at .045. While replacing the plugs I the found plug wires wired wrong. I rewired to chilton's specs. car ran mutch better for a mement (i.e. idled & reved fairly well) I closed the hood and that's when it stopped running altogether. I'm stumped I've checked the fuel pressure (because someone said it was her fuel pump) the fuel pump seems to pump ok and I get 48psi at the regulator. I also found the coil had the ground wire cut seemingly quite a while back (it ran in this condition). When the coil ground wire is connected it won't even try to fire. I also had the ICM checked it tested ok. I tested the coil output with an old spark plug and got showers of sparks. I tested the spark at the #1 plug and got irratic and weak spark. Both these last 2 tests were done with that coil wire disconnected. with it connected nuthin'. any help would be greatly appreciated.
Mndwg1 is offline   Reply With Quote
Old 10-29-2005, 09:52 PM   #2
ct91rs
Re: 85 camaro innition problem
Are you sure that's a ground wire? Most of the coils I've come across are grounded to the intake by their mount.
“When a whole nation is roaring Patriotism at the top of its voice, I am fain to explore the cleanness of its hands and the purity of its heart.” - Ralph Waldo Emerson
ct91rs is offline   Reply With Quote
Old 10-30-2005, 04:46 AM   #3
Mndwg1
Re: Re: 85 camaro innition problem
Not really sure. I just assumed. there are two two wire harnesses connected to the coil one from the ICM in the dist. and one from a larger harness that has the power red, 10 to 12ga. and this phantom wire that has been cut for a what appears to be a long time maybe 14 to 16ga. that is black with a white stripe.
Old 10-30-2005, 07:20 AM   #4
Morley
Re: Re: Re: 85 camaro innition problem
That "phantom" wire is the EST wire, electronic spark control wire. that is the wire you are supposed to disconnect to set the base timing. There should be a connector in that wire by the firewall over on the passenger side. If the car won't attempt to run with it connected, the spark control may be bad IF the timing is set correctly. If you have bad/irratic spark on #1 replace the cap and rotor. Also... spark plug gap should .035", the .045" listed on the under hood decal is wrong, GM found that it was too much gap and was causung the ignition modules to burn out.
Morley is offline   Reply With Quote
