Old 10-12-2005, 07:58 PM
Petertrack Petertrack is offline
Question what does check gages light mean?
I have a 96 blazer LT with about 140,000 miles on it. my check gages light came on about 3 days ago. there is a funny smell coming from the engine and a little smoke when I pop the hood. It also has little jerks or surges when I drive it. I know for a fact my air filter is filthy and I have just been lazy about changeing it but something tells me it bigger than just my air filter. Any ideas what it is and how to fix it? Is it my transmission?
Old 10-12-2005, 08:36 PM
BlazerBoyLT98's Avatar
BlazerBoyLT98 BlazerBoyLT98 is offline
Send a message via AIM to BlazerBoyLT98 Send a message via Yahoo to BlazerBoyLT98
Re: what does check gages light mean?
Check gauges or check engine? Or SES (service engine soon)?
2002 Pontiac Gram Am
K&N Air Filter
Mobil1 5W-30 Extended 15K
2 JL Audio 12" Subs Sealed JL Audio Box
Coustic 400 Watt Class D Mono Amp
Pioneer Head Unit 50X4 MP3, WMA, AAC Super Tuner
Polk DB750 6.5" all around
Yankees Suck!!!!!!!!
Old 10-12-2005, 11:05 PM
JC327's Avatar
JC327 JC327 is offline
Check guages light comes on if you are overheating, have low oil pressure, low voltage, etc. It is alerting you to look at your guages and see what is wrong. From what you are saying, it sounds like you are probably overheating.
Check your coolant and your oil. Don't drive around like that or you won't have an engine left to repair.
Old 10-13-2005, 12:24 AM
wolfox's Avatar
wolfox wolfox is offline
Send a message via Yahoo to wolfox
The check gages light will come on when there is an anomalous reading in the analog dials in the dash. Mine lit up and a quick glance down showed a mild overheat. This was about 3-4 months ago when my lower intake seals went and it got low on coolant. Like JC327 said, when the gages go wacky on you or read high or low, that will light up to draw your attention.
Old 10-19-2005, 04:35 PM
Thanks for the help guys. it was my coolent, cause it was low but I guess that means I got a leak somewhere.
Old 10-19-2005, 10:57 PM
herkyhawki herkyhawki is offline
Re: Re: what does check gages light mean?
what does check gages light mean?.
That light means you should check your gauges.
Old 10-19-2005, 11:03 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: Re: Re: what does check gages light mean?
Which means one of the following:
Fuel Level is low
Volt Gauge Reading WEird
Engine is Overheating
Oil pressure is low
You should be paying more attention to this, that smell was you engine overheating and the temp gauge will have to be high for that to happen.
Pay attention mopre next time and actually CHECK THE GAUGES.
Old 10-19-2005, 11:32 PM
DINO55's Avatar
DINO55 DINO55 is offline
Hey peter, If you overheated your truck, Change you Engine oil and filter ASAP.
1998 BLAZER LS Vin-W 4Dr 2wd
2004 Cavalier LS 4Dr 2.2 Ecotec
"Good Part's ain't Cheap--Cheap Parts ain't Good"
Old 10-19-2005, 11:37 PM
BlazerLT's Avatar
AF -Advisor
Why?
Old 10-19-2005, 11:56 PM
DINO55's Avatar
Because after the Oil temp reaches around 250F it has begun it's break down.
Old 10-20-2005, 03:50 AM
BlazerLT's Avatar
AF -Advisor
Nah, it is made to withstand much higher temps than that.
Old 10-20-2005, 05:56 AM
DINO55's Avatar
Hmmmm, I did not know that.
Old 10-20-2005, 05:45 PM
BlazerLT's Avatar
AF -Advisor
No problem, an oil change is only necessary if coolant gets in the oil.
