Go Back   Automotive Forums Car Chat > Chevrolet > Blazer > How-to | Technical Info
How-to | Technical Info A wealth of information at your disposal.
Old 01-08-2006, 05:26 PM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
How-to change the PITA #3 spark plug
So many threads have gotten started asking how to change the #3 plug because the intermediate shaft is in the way. "Typically" people say to wedge the socket on, use a wobble, this that an the other thing. They end up fighting with something they don't have to.
So I've decided to show the "EASIEST" way to change the #3 spark plug, (It is by no means the only way). My how-to can be done in about 5 minutes.
Tools needed.
11mm socket
Socket Wrench
2 or 3 Extensions
Flathead screw driver (or prybar if rusty)
Step 1: Turn your wheels straight and leave the ignition key forward enough to keep the steering wheel unlocked.
Step 2: Open the rag joint cover at the base of the intermediate steering shaft.
Step 3: Remove the 11mm bolt at the base of the intermeiate
Here in the picture we see the plastic rag joint cover. The red arrow points to the circled 11mm bolt that has to be removed.
Here is a pic of the bolt removed
Step 4: Use a large flat head screw driver at the base and pry outwards. The steering shaft will start telescoping in on itself. (If your intermediate shaft is a bit rusty, simply spray the shaft with wd40 or similar and use a prybar instead of the screwdriver. Don't worry about prying to hard, the shaft can take a lot. )
Step 5: Lift Steering shaft out of the way (don't worry, the top is fairly mobile)
Do not worry about how you put the shaft back on. The shaft and the splines on the steering box are keyed. (Meaning it only goes on one way) Avoid spinning your steering wheel all the way around though. You don't want to bust the clock spring in the steering wheel.
Here we now see the # 3 plug fully accesable. Simply use a couple of extensions and a spark plug socket to remove.
When putting in new spark plugs, even if you are told they are pre-gapped, take no chances. Check your gap with a gap tool. It's a .25 cent tool, get one! Also you can spread anti-seize on the threads of the sparkplug so you don't have difficulty later. Also use dialectric grease inside the plug boots. This way you won't have a prob when you need to pull them off later and it will create a better contact between the wire and the plug.
Here is a shot of the AC-Delco Rapidfires that I installed. Note the gold tone, that is the anti-seize.
Total time to change all 6 plugs was 20 minutes. This includes collapsing and reinstalling the intermediate shaft. This way you don't have to worry about trying to work other tools in there.
95 s10 Blazer, EGR Mod, ZQ8 Steering box mod, 99 Center console shifter mod and more... See everything at www.pghconsulting.net/teal
Old 01-08-2006, 06:10 PM
2000blazerls's Avatar
2000blazerls 2000blazerls is offline
Re: How-to change the PITA #3 spark plug
Good post, wish I would have had it a couple of months ago when I did my wire/cap/rotor/plug change!!!
Heh, will keep this in mind for next time though!
Bye Bye Blazer!
http://www.cardomain.com/ride/2159611
Hello Monte Carlo!
http://www.cardomain.com/ride/2445379
Old 01-08-2006, 07:04 PM
blazee's Avatar
blazee blazee is offline
Problem?
Another great thread. Now that people can see how to do it, maybe they'll believe us when we tell them it's easier than fumbling with multiple swivels and extensions.
Old 01-08-2006, 07:31 PM
s10blazerman4x4's Avatar
s10blazerman4x4 s10blazerman4x4 is offline
Send a message via AIM to s10blazerman4x4
Hey the pic worked the first time this time lol.
1991 Chevy S-10 Blazer 5.7 V8 RIP
1999 Chevy Blazer 2dr 4.3
Old 01-08-2006, 09:28 PM
CEO Wrench CEO Wrench is offline
Great post!
Old 01-09-2006, 08:46 AM
BlazerBoyLT98's Avatar
BlazerBoyLT98 BlazerBoyLT98 is offline
Send a message via AIM to BlazerBoyLT98 Send a message via Yahoo to BlazerBoyLT98
Pretty awesome!
2002 Pontiac Gram Am
K&N Air Filter
Mobil1 5W-30 Extended 15K
2 JL Audio 12" Subs Sealed JL Audio Box
Coustic 400 Watt Class D Mono Amp
Pioneer Head Unit 50X4 MP3, WMA, AAC Super Tuner
Polk DB750 6.5" all around
Yankees Suck!!!!!!!!
Old 01-09-2006, 08:17 PM
foon foon is offline
Thanks again rlith, first it was the door hinge bushing post and now this!!! you are a life saver
Old 01-09-2006, 11:28 PM
Bravada 97's Avatar
Bravada 97 Bravada 97 is offline
Great info. I wish I had that last fall when it took me 2 hours to change all my plugs. LOL.
Old 01-10-2006, 04:24 AM
Rmbodie's Avatar
Rmbodie Rmbodie is offline
Glad its not this difficult on an 89 model . But a body lift helps with clearance . Another good job . Rob
2000 Trans Am six speed Blackbird .Fast enough stock!
2005 Grand Prix.
2005 2500HD Silverado 4x4 , Duramax!!!!!!! Lifted ,Pumped,Humped,Thumped!
1988 JEEP Cherokee: Lifted, Sons new toy.
Old 01-10-2006, 09:38 AM
I might actually need this for v8 because from plug 3 on back its a no go lol.
Old 02-14-2006, 12:05 PM
2kTrailBlazer's Avatar
2kTrailBlazer 2kTrailBlazer is offline
Send a message via AIM to 2kTrailBlazer
Thats awesome, just another idea as well...snap-on makes an offset sparkplug socket that works great too
Old 02-14-2006, 04:58 PM
friesza friesza is offline
I guess my question would be....would this effectthe air bag system in any way?? Just dont want to set off my airbag over a spark plug...lol
Old 02-15-2006, 06:24 AM
rlith's Avatar
No, it won't affect the airbag system. Your airbag sensors are actually under the core support, so unless you bang those with a hammer you've got nothing to worry about
Old 03-07-2006, 07:18 PM
excheezhead excheezhead is offline
good advice, dude master, i also found on my 2001 jimmy, the flap behind the front wheels/tires, if lifted up, gives good acess to the other 5 plugs, and nothing above has to be removed. i got off easy last time i changed #3, as i used a wobble socket extention and ground a few mm's off both ends of the spark plug socket. it was still hard, but went better that witha regular socket. p.s. are the ac/delco's you put in working well, i put in a set of bosch platnum +2's and i don't think it was worth the money. thanks for the info/helpand graphics are always good!!!
excheezhead.
Old 03-30-2006, 01:49 AM
thorbergdt thorbergdt is offline
Thanks for the easy steps, even on my 2001 blazer it was almost exactly as you wrote. Im a complete car novice (can hardly change my own oil if i had to) And i got this granted it was a biatch my engine cavity had about 10x the wires as shown in your pictures but with a little TLC you can make it happen!
