Old 09-21-2005, 10:05 PM
iFooLisHPLeaSureZi iFooLisHPLeaSureZi is offline
Question Turbo PReLude .. H22+H23 ?
i have an h22 engine.. and im buying an h23 prelude .. im guessing best bet is use the h22 vtec head and put it on the h23 base .. that plus t3 turbo it out .. or t4, to4e w.e turbo i find is best ..i need some opinions and common knowledge on whats the best route 2 go .. what turbos are available for these engines .. and what i should do with them .. keep the h22 and m0d that heavily or stick with h23 and do the same .. ive been told to mix them like i said to get the best results .. vtec head h23 base and then turbo to get that .1 more liter and have vtec timing at the same time for the best of both engines .. is this true ??? ive heard since the h23 has more liter space its better to turbo cuz u get more out of it ..is this true???? the h22 has been said to be a more complicated engine to deal with .. turbo .. all that .. any info, knowledge or ideas are appreciated =)
Old 09-22-2005, 06:16 PM
honda_racing101's Avatar
honda_racing101 honda_racing101 is offline
Send a message via AIM to honda_racing101 Send a message via MSN to honda_racing101 Send a message via Yahoo to honda_racing101
Re: Turbo PReLude .. H22+H23 ?
Don't do the h23 block/h22 head. Many people can't get it to run right, and since you already have a h22 engine, keep it. As far as turbos go, you need to search. You should know that anyhwere from 7-10 psi is safe on a stock engine with a good tune.
dSoc member #67
1995 Honda del Sol EG2 VTEC Milano Red. RIP :crook:
1994 Honda del Sol EG1 S-full VTEC conversion.
Buy my Del Sol parts!!
Old 09-22-2005, 07:05 PM
thanx guy =) anyone else?
Old 10-01-2005, 09:58 PM
lude_92 lude_92 is offline
Send a message via AIM to lude_92
Don't go turbo.... Your best bet would be to supercharge it... My buddy Turbo his lude and another friend of mine blew him away with the same car same engine mods cept a supercharger... plus with the supercharger you always have power no time for spooling... less strain on an engine.
Old 10-01-2005, 10:25 PM
SiGNAL748's Avatar
SiGNAL748 SiGNAL748 is offline
Send a message via AIM to SiGNAL748 Send a message via MSN to SiGNAL748
You're retarded.
Old 10-02-2005, 10:15 AM
Re: Re: Turbo PReLude .. H22+H23 ?
Originally Posted by SiGNAL748
You're retarded.
What!!! A supercharger is much better then a turbo..
Old 10-02-2005, 12:35 PM
SiGNAL748's Avatar
Re: Re: Re: Turbo PReLude .. H22+H23 ?
I'm not saying one is better than the other. Your logic is completely off. Exactly what engine mods did they have that were the "same"? Were they both running the same psi? Were they both dyno tuned? Was this from a dig or a roll? There are too many factors involved to say that one is better than the other.
Old 10-02-2005, 02:16 PM
94PreludeJDM's Avatar
94PreludeJDM 94PreludeJDM is offline
Plus the potential of the turbo is way way higher than that of a turbo. What kind of a turbo set up did your friend have? I gaurantee a light engine build and a T3/T4 turbo at like 10 psi will blow a JRSC out of the water. There's a reason why so many people do turbo over a supercharger. Not to knock them though, they're great for auto-x and things, but if you're looking for straight speed, the turbo dominates.
Old 10-03-2005, 02:04 AM
AllmotorBB6 AllmotorBB6 is offline
If you're not an idiot and let someone build the motor for you that has done it before, then i would do it and turbo it if you really wanna make some power that is respectable.
Old 10-19-2005, 12:44 AM
ive heard more good things about a turbos potential by far
Old 10-19-2005, 04:18 AM
ajs42 ajs42 is offline
have a 95 H23 I was going to turbo
I would just stick with the H22 to make the H23 a Vtec take alot of time and work and it isnt really worth the .10 litres. I had a H23 in my 95 SI til the timing broke snapped and the engine got messed up. If you need some links to turbo kits for ludes let me know I have a few.
