99 gls rear suspension
I need a right rear knuckle axle carrier assembly and a right rear hub assembly with bearing. There is no abs and there are disc brakes. Are there any aftermarket companies that carry these parts? And if anyone knows where I can get these please let me know. I've tried sevral junkyards and they don't even have the car. I found one sonata but it had drums in the rear and I think those parts are different, can anyone confirm this?
Nissan, Subi, Yoter, Ford |
I looked at hmaserivce webtech and under both the v6 an 4cyl views of the rear suspension it is the same picture. I need the knuckle axle carrier assembly, the thing that mounts to the upper arm and assist arm. So from what I can see it is the same part. Can someone look at this and tell me if I'm right.
Re: 99 gls rear suspension
If I call a hyundai dealership parts department will they confirm this or will they not want to tell me? lowsonoma1999 do you know anything about how the parts department works?
The carrier doesn't matter between the 4cyl and V6. It does make a difference between disk and drum, and with or without abs. The V6 only came with disk brakes, and some 4cyl came with disk, but mostly drum. For the carrier you need, part # is 52720-38200. List price is $507.48. The rear hub part # is 52730-38003, which lists at $212.48. I'll sell you both for $550 plus freight. I have the hub, but not the carrier, so it'll take me a couple days to get that. I don't know where you are at, so freight might be a bit. The carrier does have some weight to it.
John Nance Parts Manager Terry Lee Hyundai 17665 Terry Lee Crossing Noblesville, IN 46060 |
Re: Re: 99 gls rear suspension
Re: Re: Re: 99 gls rear suspension
Nissan, Subi, Yoter, Ford Last edited by quickywd01; 10-13-2005 at 09:24 AM. |
