Old 09-26-2005, 05:29 PM
rcontratto rcontratto is offline
Unhappy 1990 Civic Erratic Idle Problem
My 90 Civic DX started idling very erratically a while back. The RPMs will go up and down throughout driving... with the engine hot or cold. Any ideas on what it is?? I'm not getting any codes from the ECU so far. My grandpa thought it may be the dashpot, but not sure.
Old 09-26-2005, 05:35 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
Re: 1990 Civic Erratic Idle Problem
check all vacuum hoses for cracks and leaks
make sure hteres enough coolant.
try take off the iacv and clean it and see if that fixes it.
try all that and post back up and let me know if that fixes it or not
Team Lonely Drivers
Old 09-26-2005, 10:41 PM
mrgofast21018's Avatar
mrgofast21018 mrgofast21018 is offline
Send a message via AIM to mrgofast21018
does it have ac? i thgink i read somewhere that the compressor clutch sometimes...errr does something. but if the erratic idle happens when you got your ac on....
gimme some time. ill think of something witty and clever to put here.
Old 09-28-2005, 11:36 PM
cleaned the eacv, coolant is ok, and the hoses are ok... thought i had it fixed but then it threw a code 5 (map)... turns out i had forgot to hook up the vac line from the MAP to the TAS... plugged it back in and the erratic idling started again..
just out of curiosity i unplugged the elec from the TAS and that stopped the erratic idling also.
and other ideas??
oh, and the prob happens whether the ac is on or not...
Old 09-29-2005, 12:18 AM
slipknotcraig133 slipknotcraig133 is offline
Send a message via AIM to slipknotcraig133
when you say your coolant is okay was the radiator just full or did you bleed it
Got the car 1400
Need an H22a4 4000
Some Goodies to go Along With it 2000
Some Drag Slicks 750
Going to the Strip and Make V8's Say D*** Hondas PRICELESS
