Old 09-16-2005, 03:26 PM
SMOKINGIROC SMOKINGIROC is offline
Question Jet Fuel ?
My buddy is in the navy and fuels jet planes, well my question is he could get me some jet fuel now would that be safe to put in my car or will it blow it up? i dont know what octane it has.
1989 IROC,NEW GM 350 H.O VORTEC ENGINE, HI-FLOW VORTEC TPI SYSTEM, SLP CAI, SLP HEADERS, 3" FLOWMASTER CAT-BACK, PORT & POLISHED HEADS, CORVETTE SERVO, SHIFT KIT, B&M MEGA SHIFTER, HOTCHKIS SUSPENSION,
Old 09-16-2005, 03:42 PM
CamarosRsweet94's Avatar
CamarosRsweet94 CamarosRsweet94 is offline
Re: Jet Fuel ?
Does you car not run well on regular gasoline?
1994 3.4L Chevrolet Camaro - No more
2006 Hyundai Sonata
Old 09-16-2005, 03:48 PM
Re: Jet Fuel ?
It runs good, but i'm talking about taking her to the track with jet fuel.
Old 09-16-2005, 04:06 PM
balls_to_the_wall's Avatar
balls_to_the_wall balls_to_the_wall is offline
Re: Jet Fuel ?
dosen't all jet fuel have is a very high octane rating?? No powerbenifit, along with absolutley 0% water?
Please correct me if i'm wrong (which is almost a given...)
-Ryan
Old 09-16-2005, 04:49 PM
Savage Messiah's Avatar
Savage Messiah Savage Messiah is offline
Send a message via AIM to Savage Messiah Send a message via Yahoo to Savage Messiah
Re: Jet Fuel ?
just post up after with pics of the aftermath on that 350 HO... and I take no responsibility...
97 Camaro - 2.077 60', 14.745 @ 92.20 - still down, one year later.
194k miles-160* thermo-V8 shocks/springs (V6 rear springs)-3" Magnaflow !cat (3" dynomax bullet) back-SLP CAI-stock boxed LCAs-poly tranny mount and torque arm bushing-custom HPTuners tuning-4.10s/eaton/TA girdle-3.5" alum DS-spohn LCA brackets-prostar skinnies
179.75 RWHP, 204.52 RWTQ
ON ITS WAY: MORE
R.I.P. Andy
87 Benz 190e - DD
01 EX250 - still gotta get my license for this thing
Old 09-16-2005, 05:07 PM
99markss 99markss is offline
This is right up my alley, I am in the Air Force and my job just happens to be a Fuels Specialist aka POL. Jet fuel is a kerosene based fuel, ala diesel, only much cleaner. There are various grades of jet fuel, the USAF flies on JP8, which has a flashpoint of over 100 degrees. The commercial airliners use Jet A, only difference being absence of certain additives the military requires for safer handling and performance such as Fuel System Icing Inhibitor (FSII), which prevents the entrained water, which is in all fuel, from freezing at higher altitudes, kind of antifreeze for fuel. So as to using it in your car, I would highly discourage it. Jet fuel would most likely destroy your spark plugs if not more. You would be better off using AVGAS, but only in small amounts.
Jet fuel is for jet engines.
Old 09-16-2005, 05:08 PM
ct91rs ct91rs is offline
Re: Jet Fuel ?
From what I understand, most jet fuels have a 15-20 octane-equivalent rating. (i.e. they ignite very easily and would quickly blow your engine.)
“When a whole nation is roaring Patriotism at the top of its voice, I am fain to explore the cleanness of its hands and the purity of its heart.” - Ralph Waldo Emerson
Old 09-16-2005, 05:10 PM
Rally Sport's Avatar
Rally Sport Rally Sport is offline
Is eating.
Send a message via AIM to Rally Sport Send a message via MSN to Rally Sport
I wouldnt use jet fuel even without knowing all the stuff this guy just told us.. Mainly because everyone knows that jet fuel burns a long time.
Old 09-16-2005, 05:41 PM
y2icon's Avatar
y2icon y2icon is offline
Send a message via AIM to y2icon Send a message via Yahoo to y2icon
Re: Jet Fuel ?
could be a good thing on gas mileage but proly would end up destroying the car, but hey if cars can run on vegetables why not jet fuel
Nitrous= the car equivalent of a penis pump
Old 09-16-2005, 10:57 PM
Morley Morley is offline
Re: Re: Jet Fuel ?
As stated above...jet fuel is kerosene, which is very hard to ignite. It won't blow up an engine from all of the "power"...it will foul the plugs horribly though.
Old 09-17-2005, 01:29 AM
supervisor1886's Avatar
supervisor1886 supervisor1886 is offline
Banned
Re: Jet Fuel ?
dont wold war2 planes used kerosine based fuels ? +nitrous. I have seen those 16 cylinder engines (1200hp) from Focker wolf planes.
Old 09-17-2005, 02:29 AM
demon9766 demon9766 is offline
Send a message via Yahoo to demon9766
Re: Jet Fuel ?
Don't put jet fuel in your car dude! Better to use AV gas I use it but I have forged pistons and zero gap rings.IF you do use AV gas be sure to mix it with super unleaded because the AV gas is so dry it will hurt your fuel system and melt your pistons if you don't.
This is what 500 plus hp looks like.CNC ported AFRHEADS WITH 2.02 INT 1.60EXH,210 intake runners 74cc chambers, 750 speed demon carb,weiand intake,comp cams 292 with .501/.501 lift ,4340 forged crank,eagle H-beam rods duroshield bearings,KB forged 10 1/2:1 pistons,headers with 1 3/4 primaries ,MSD 6AL,comp cams pro mag1.6 rockers,holley blue pro-series pumps,MSD billet distributor.All stuffed into a 355.[img][/img]
Old 09-17-2005, 09:23 AM
Re: Jet Fuel ?
Well, I guess IMO if the car runs fine on high octane gas why not just stick to running that? Unless the car doesn't run well on gas anything else is kind of a waste I think...
2006 Hyundai Sonata
Old 09-17-2005, 11:21 AM
Scale-Master's Avatar
Scale-Master Scale-Master is offline
AV Gas will not destroy your fuel system. But who would waste the money to run pure AV Gas in a stock street car anyways. Check the dollar per gallon.
I run a few gallons in a full tank of pump preimium to bring the octane rating up to between 102 and 104. Anything more is a waste and fouls the plugs. Unless it was free, I wouldn't put it in a stock motor. I only use it in my Z with a built 385, yes I said 385... - Mark
Old 09-17-2005, 07:52 PM
CamaroRS92 CamaroRS92 is offline
The old farm machinery and trucks used to run on Kerosene years ago because it was cheaper back then. They had a dual fuel tank Gasoline on one side and Kero on the other. They would start the engine on Gasoline and let it warm up then switch over to Kero. Then just before shutting the engine off they would switch back to gasoline for a short time to burn the remaining kero out of the carb.
You could prob. run it without damaging the engine (other than possibly fouling plugs) as long as the engine is good and hot before trying to run it & you dont turn the engine off and let it cool down with a tank full of Kero Base Fuel, or you might not get it started again.
Spark ignition is not hot enough to ignite it alone (unless you preheat the Kero. to near the flash point) and very doubtful you have the compression to ignite it like a diesel engine does.
Power gain? - very doubtful
Economical? - Not
I see no real advantage with it
