Old 10-24-2005, 08:30 AM
guillermo9844 guillermo9844 is offline
remove and install radio 1992 jeep cherokee
how do i remove and install radio for 1992 jeep cherokee. thanks a lot.
Old 10-25-2005, 02:57 AM
maltesesteeze maltesesteeze is offline
there are four screws to remove. two above the gauges and one on either side of the steering wheel in the little dash sections where the light knob is on the left and where the fog light switches go on the right, your jeep may not have foglight switches there but the space is the same. Theyre all on the under side of the dash panel so they are a bit hard to spot if you dont know where they are, but youll find them. From there you remove the dash by just pulling it out slowly but firmly, be careful of the little u shaped piece underneath the steering wheel that pops out seperately. Unscrew the stereo from the two noticeable side screws holding it in. As far as wiring it all depends on what youre putting in, but that should get you started.
