Go Back   Automotive Forums .com Car Chat > Buick > LeSabre
Old 09-04-2005, 10:54 PM   #1
snidz
Send a message via AIM to snidz Send a message via MSN to snidz Send a message via Yahoo to snidz
Where is the cam shaft sensor at?
Hi, I was wondering if anyone knew where the cam shaft sensor is on a 89 lesabre?
snidz is offline   Reply With Quote
Old 09-05-2005, 12:27 AM   #2
spinne1
Re: Where is the cam shaft sensor at?
Okay, I've read this one second, so now I can tell you....it is located on the front cover of the engine, just below the water pump. It will be at the end of the only wire harness going to the middle area of the front cover. It is attached to the front cover with a 10 mm bolt (I think). The only other wire harness on the front cover is going to the crank sensor, which is behind the harmonic balancer (crankshaft pulley). You may have to remove a few things to easily access it, or maybe not, I don't remember.
spinne1 is offline   Reply With Quote
