Old 09-01-2005, 08:40 PM
GirlBear's Avatar
GirlBear GirlBear is offline
I 'e Got some Codes Doesn't sound good.
If you guys can make heads or tail of these I'd be real interested to know. cause the idiots at advance couldn't give me any answers.
http://jowulf.deviantart.com/
Old 09-01-2005, 11:17 PM
dmbrisket 51's Avatar
dmbrisket 51 dmbrisket 51 is offline
Send a message via AIM to dmbrisket 51
Re: I 'e Got some Codes Doesn't sound good.
do a full tune up, including all 3 o2 sencors
Old 09-01-2005, 11:19 PM
DINO55's Avatar
DINO55 DINO55 is offline
http://www.asashop.org/autoinc/june2002/techtips.cfm
Your random/multiple cylinder misfire could be caused by many things... Bad spark plug, bad wire(s), bad/dirty dist cap , bad or loose rotor, bad/dirty gasoline and filter. these are some of the obvious things to look at first GirlBear. Good Luck
1998 BLAZER LS Vin-W 4Dr 2wd
2004 Cavalier LS 4Dr 2.2 Ecotec
"Good Part's ain't Cheap--Cheap Parts ain't Good"
Old 09-02-2005, 07:33 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Girlbear,
Listen to me.
How many miles on your truck?
You passenger side O2 sensor is defective and needs to be changed. That is the only one showing a code.
Also with the Misfire code, you probably need a tuneup including:
Fuel filter
Spark plugs AC Delco Platinum only
Cap & Rotor
Air Filter
PCV Valve
