Ok, I'm trying to get the instrument panel with the speedometer and all the other gauges off. I can't get it off because the top of the steering column thing is in the way. How do I get it off so I can change the lights behind the gauges? Please I need help.
Re: How do I get the instruments panel with all the gauges off so I can change the li
here it comes... Did you do a search? .. I've always wanted to post that. I posted how to remove the cluster cover to replace the radio, it's the same for replaceing or cleaning your cluster... 1) Always un hook your neg post from battery. 2) pop the dash bezel out a) undo the four screws/bolts holding it in b) put your blazer in 1st (press on the brake real hard adn have the emergency on, unless you have blocks behind your tires so it doesn't move, turn your ignition to the on position) c) drop your tilt all the way down Now you have clearance to shimmy that sucker out, don't forget to unhook your 4x4 switch and any other cables you need to take off. That's it, just be careful when you are pulling the plastic, it's flexable, and will need some toying with to get out, but it will pop out. ~Xpc |
Re: How do I get the instruments panel with all the gauges off so I can change the lights
tried doing that on mine and still wouldn't come out.
95 jimmy. Vortec V6. 4.3 liter CPI. ,2.5" catco cat, 2.5" cat back with flowmaster muffler split rear., 40 street series, 2 12" audiobahns in custom box,K&N CPI intake system. 71 Mustang coupe- project car. stock 302 with Cobra intake, holley 650dp, afco racing radiator, headman headers, msd distributor, 2.5" from the headers.C4 tranny with shift kit, Mach 1 body lay out. 90 cav, 2.2 tbi, gas getter. 99 chevy s10 zr2, 6" lift, duel exhaust. 5 speed. |
