Old 05-06-2002, 10:14 AM   #1
jsraaf
Speedometer displays incorrectly on '93 Accord
On my '93 Accord SE I am having an issue with the speedometer registering 10-15 mph higher than the actual speed. It seems to be (more) correct at speeds under 40mph or so, but at highway speeds is very far off.
Occasionally I will see the needle jump downward to what I assume is the correct speed, then later it resumes it's incorrect display. It appears the tachometer may also be off, as it seems to intermittently be registering lower than what I believe it should
I have been told that to correct this, the entire dash or instrument panel may need to be replaced, rather than any wiring/cabling for the speedometer.
Any insights on this issue are greatly appreciated!
jsraaf is offline   Reply With Quote
Old 05-07-2002, 12:06 AM   #2
TheCarotman
Send a message via ICQ to TheCarotman Send a message via AIM to TheCarotman
yeah the gauge cluster could be deffective or your speed sensor (you might want to check that)
Are your tires still the stock size?
http://pages.infinit.net/omus
TheCarotman is offline   Reply With Quote
'93 Accord headlight problem - not coming on jsraaf Accord/TSX/Accord Hybrid 4 01-03-2014 07:11 PM
1What does it mean when a 1993 Honda Accord needs an service tune up? tools951 Accord/TSX/Accord Hybrid 1 02-12-2011 02:06 PM
Speedometer Display - Instrument Panel mooneyka Xsara | Xsara Picasso 0 01-06-2010 07:52 AM
Steam, overheating on my '93 Accord? Kuroneko Accord/TSX/Accord Hybrid 8 09-14-2004 03:09 AM
remote for amp '93 Accord PolarCivic Car Audio 8 11-08-2002 08:05 PM
