Old 02-18-2005, 03:21 PM   #1
Ragtop68
Question Installing Overhead console
What needs to be done to install an overhead console in a 95 Blazer. Are there mounting brackets preinstalled under the headliner or what?
If it's a full function display, will the compass and temperature functions work by just supplying power?
Thanks,
Al T.
Ragtop68 is offline   Reply With Quote
Old 02-18-2005, 04:57 PM   #2
rlith
rlith's Avatar
Send a message via AIM to rlith Send a message via MSN to rlith
Re: Installing Overhead console
Thanks,
Al T.
No, the brackets aren't pre installed, you will have to fab your own...You will need the temp sensor that goes up in the rad support behind the grille, and you will also need to tap into the VSS signal, as well as power, and ground.
95 s10 Blazer, EGR Mod, ZQ8 Steering box mod, 99 Center console shifter mod and more... See everything at www.pghconsulting.net/teal
rlith is offline   Reply With Quote
Old 02-18-2005, 10:43 PM   #3
chcknugget
chcknugget's Avatar
Send a message via AIM to chcknugget
Thanks,
Al T.
I just cut little pieces of wood and inserted them into the roof crossmembers. You can screw your console into them and it works really well.
Make sure you get an "on/off" computer because a "mode" one will not work.
chcknugget is offline   Reply With Quote
Old 08-07-2005, 02:26 PM   #4
resistol30
Send a message via MSN to resistol30
installing in a 96
Same question, but does anyone have a wiring schematic. I need to know which wires are for what.
resistol30 is offline   Reply With Quote
Old 08-08-2005, 12:19 AM   #5
RedLT
RedLT's Avatar
Nice Blazer 89
Red 1995 Chevy Blazer 4X4
Check it out.
http://www.cardomain.com/ride/2071240
MODs
Brush Guard 2/20/05
Bigger tires 3/15/05
Flowmasters 6/18/05
Minor Paint work 2005
Upcomming
6 inch lift 0-6 months
Swampers 0-6 months
Dual Flowmaster Exaust 6-12 months
RedLT is offline   Reply With Quote
