93 camaro
So whats up with a 93 camaro? did it have a 700r4 with an lt1 motor? And if that is the case then couldnt you just do an lt1 swap and use a 93 computer? Were there lots of problems with the 93's? its just that I never see anything about 93 camaros. just 94 and up.
92 z28 camaro 5.7 TPI current - slp intake runners and base-BBK 52mm throttle body-MSD 8.5mm wires, blaster coil, and 6AL Box-edelbrock headers-160 degree stat.-hotchkis strut tower brace waiting in the garage - LQ4, milled heads 317 casting (10.5 to 1), hardened pushrods, ported LS6 oil pump, manley dual spings with titanium retainers, MTI X1 cam, hawks longtube headers
Re: 93 camaro
The 93 had a 4l60 tranny or the 6 speed without the electronic controls and yes its pretty much exactly like a 700r4 and its a easier swap to use that with a 93 computer but the 93 used speed density which doesn't react as well to mod's unless your very accurate with the programming which does have a removable prom chip, so you can't program from inside the car like 94 - 97. Also the 93 has smaller injectors (22lb vs 24.9lb on later), the intake manifold , fuel rails and oil pressure sending unit is also different and in a different location but the block itself is exactly the same but the heads are slightly different with some extra material around the under part.
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart. Mods: Weight reduction (I don't wear underwear) |
Re: 93 camaro
ok so it did have the 4l60e tranny in it. Someone at sometime told me that it still had a 700r4 tranny in it meaning not computer controlled. So have people had a lot of problems with the 93? A friend of mine is looking at one but i dont know if it would be a good one to get. But shes not looking for performance she just likes camaros. Its only 1000 dollars. I havent looked at the car but supposed its in pretty decent shape.
Re: Re: 93 camaro
- Jason 1995 Pontiac Firebird ![]() ![]() User Guidelines | VB Codes Explained | AF Merchandise "Each of us, is in the scheme of things, insignificant. But millions of insignificant people, doing a tiny bit, can add up to be a very significant force." |
