Go Back   Automotive Forums .com Car Chat > Dodge > Neon | Plymouth Neon > 1st Gen 95-99
Old 09-16-2006, 11:50 AM   #1
fast98rt
turbo questions!!
i have 98 neon 2.0 dohc that i want to turbo.....i was wondering if the stock srt4 turbo and manifold will bolt up and clear everything....and i have heard that the stock actuator only allows about 6 pounds of boost...whats the truth in that?
fast98rt is offline   Reply With Quote
Old 09-17-2006, 09:24 AM   #2
das2123
Tuning Neons since '97
Send a message via AIM to das2123 Send a message via Yahoo to das2123
Re: turbo questions!!
Yes the SRT-4 turbo and manifold bolt up to the DOHC head. The stock limit is set 4 lbs of boost.
If you want to turbo your neon, you will need more than the turbo and manifold.
2003 Dodge SRT-4
das2123 is offline   Reply With Quote
Old 09-17-2006, 09:55 AM   #3
Bear
Bear is offline   Reply With Quote
Old 09-17-2006, 04:17 PM   #4
das2123
Originally Posted by Bear
Whats that for?
2003 Dodge SRT-4
Old 09-17-2006, 04:51 PM   #5
Bear
You asked about turbos for Neons, well Howell has the kit and has had for years.So if you are serious, check it out.
Old 09-17-2006, 04:56 PM   #6
das2123
I didn't ask about anything. fast98rt did and he asked about the SRT-4 turbo. Besides Howell Automotive's customer service flat out sucks!
2003 Dodge SRT-4
Old 09-17-2006, 06:08 PM   #7
fast98rt
thanks for the advice so far.....does anyone know a website that will tell me what i need and how to do it step by step....or anything similar....i know ill need the tubing for the intake and intercooler and i am pretty sure ill have to tap an oil line into my oil pan...but other than that i have no clue...but i am serious about putting an srt4 turbo on my car...i dont want to run high boost so i figured it would work perfect for what i want and be relatively cheap compared to a high end turbo kit....thanks
Old 09-17-2006, 06:19 PM   #8
skatendestroy
Send a message via AIM to skatendestroy
there is alot to turboing this car..... upgrading your whole entire fuel system your also going to need the srt exuast new pcm or a piggy back unit to control boost and fuel your going to need to need new pistons and rods as the stock pistons are relativly weak and i dought that is even close to everything needed
i recomend going to www.neons.org and research research research!!!
skatendestroy is offline   Reply With Quote
Old 09-17-2006, 08:41 PM   #9
fast98rt
i wont need the srt exaust....i can fab my own downpipe....and 4 lbs of boost is gonna be fine on my stock internals....i just need to know how to do the fuel system....will bigger injectors work....or will i need to do more than that? and why would i have to get a new pcm...?
Old 09-17-2006, 09:40 PM   #10
skatendestroy
different fuel tables
Old 09-17-2006, 10:07 PM   #11
Bear
Love them or hate them, everything you need to turbo your car (yes everything) can be purchased from Howell. This is a HAHN Racecraft turbo setup and it has been used on numerous Neons, comes complete with installation instructions.
PS: Last Post on this topic
Old 09-17-2006, 11:07 PM   #12
das2123
Not entirely true...just need to get a 255LPH Walbro pump and mod it for a return line. Type in spoolboy mod in google and at least 24 lb injectors.
tyour also going to need the srt exuast new pcm or a piggy back unit to control boost and fuel
SRT-4 exhaust ins't needed nor required and you use the STOCK PCM with either a missing link or MAP clamp.
They handle low amounts of boost quite well. The Hahn Racecraft kit can be installed on stock pistons and rods and run about 5-7 psi.
Stuff needed would be SRT-4 turbo/manifold, oil & coolant lines along with fittings, map clamp, intercooler and piping, turbo 02 housing, downpipe, bigger fuel pump, bigger injectors, and a fuel pressure regulator. You can get a boost controller if you'd like, but won't be necessary if you are running th stock 4 psi.
2003 Dodge SRT-4
Old 09-18-2006, 01:28 PM   #13
neon_rt
neon_rt's Avatar
I thought the stock boost level for the SRT-4 was 14 psi not 4 psi.
Not that it matters, Fast98rt is in need of a lot of expert help or he is going to hurt himself for worse yet his Neon. ;=)
neon_rt is offline   Reply With Quote
Old 09-18-2006, 01:47 PM   #14
das2123
The stock WGA is set to 4psi.
2003 Dodge SRT-4
Old 09-18-2006, 04:09 PM   #15
Bear
The December 1999 MOPAR ACTION magazine has a pictorial on the turbo installation on a first generation NEON.
