Old 07-12-2005, 11:46 PM   #1
xVANx
Send a message via AIM to xVANx
help with cold air intake install
i just bought a cold air intake kit from ebay(as recomended by people here), and turns out im really bad at this stuff and dont know how to install it. ive looked for picture by picture steps for my 2000 blazer but no luck. can anyone help me? thanks
xVANx is offline   Reply With Quote
Old 07-13-2005, 01:05 AM   #2
drdd
drdd's Avatar
Re: help with cold air intake install
well, its hard to know just what you bought off the internet but ... it should go ...
air comes in at the air filter -- followed by
the mass airflow sensor (MAF) to
the air intake
the air intake temp sensor will come after the MAF sensor. you may have to drill a hole into the "pipe" to insert the sensor ... use a rubber grommet ...
you may have to connect hose-clamps or couplers to make the proper connections ...
all connections should be as air-tight as possible ...
it's most important that the filter (air intake source) is shielded as much as possible from the heat of the engine. The idea is that the intake air should be cold ... or as cold as possible ...
also, you may have to fabricate a brace or another way to keep everything from bouncing and vibrating ...
good luck ! I'm considering the big $$ for a K&N intake system on Ebay ...
drdd is offline   Reply With Quote
Old 07-13-2005, 01:47 AM   #3
xVANx
i bought this one -
Old 07-13-2005, 02:08 AM   #4
BlazerLT
AF -Advisor
BlazerLT's Avatar
look at the picture and do it/
BlazerLT is offline   Reply With Quote
Old 07-14-2005, 01:36 AM   #5
xVANx
a quick question, i just installed it, but wonder if i need a heat shield for it?
Old 07-14-2005, 02:08 AM   #6
BlazerLT
AF -Advisor
BlazerLT's Avatar
Naw, just make sure all the pipe coupling are tight and secure.
And don't over oil the filter the next time you service it.
Filter oil will destroy your MAF if you over do it.
Old 07-15-2005, 12:54 AM   #7
xVANx
ok, cool...thanks
Old 07-16-2005, 09:26 AM   #8
BlazerLT
AF -Advisor
BlazerLT's Avatar
Re: Re: help with cold air intake install
ok, cool...thanks
Punny.
Cold air intake........cool?
Get it?
Old 07-18-2005, 12:36 AM   #9
wolfox
wolfox's Avatar
Send a message via Yahoo to wolfox
No more coffee for you 'LT, no more.
wolfox is offline   Reply With Quote
Old 07-18-2005, 01:39 AM   #10
xVANx
im glad someone caught that
