Go Back   Automotive Forums .com Car Chat > Chevrolet > S-10
Old 07-13-2005, 10:22 AM   #1
Prempt
2.5L Burning oil - going to remove cylinder head. Help please.
1987 Chevy S-10 2.5L
I am burning oil. I go through a lot of oil and I have a very very minor leak (not anywhere close enough to equal the amount of oil I lose). When I go to put oil in, I will burn off a lot of white smoke, after a while though there is no smoke yet I still will burn oil till it runs dry or near dry. I am going to remove the Cylinder head (Or at least try). After reading the "How to" in the Haynes manual, I am a little scared just because it seems like a lot of work.
My questions are -
1. I have standard garage tools. Will I need anything special to do this?
2. While I have the head off and everything else that I need to get to the cylinder head, is there anything that I should replace that isn't too costly?
3. If it's not my cylinder head, where else could the oil be coming in at?
Thanks in advance.
Prempt is offline   Reply With Quote
Old 07-14-2005, 12:08 AM   #2
drdd
drdd's Avatar
Re: 2.5L Burning oil - going to remove cylinder head. Help please.
http://www.automotiveforums.com/vbul...d.php?t=283211
http://www.automotiveforums.com/vbul...ghlight=autorx
My questions are -
Thanks in advance.
drdd is offline   Reply With Quote
Old 07-14-2005, 01:08 AM   #3
whitetrash982
Send a message via AIM to whitetrash982
far as burning oil - on high mileage cars , the 2 big things that will cause it to consume alot of oil are either the valve seals or the piston rings , of which either could be wrong if your has alot of mileage , as for tools , im honestly not familair with the engine , sorry
whitetrash982 is offline   Reply With Quote
Old 07-14-2005, 03:07 PM   #4
rstroud
Mostly just regular tools will be all that you need with the exception of a torque wrench to re-install. If you remove the valves, you will need a chevy valve spring compressing tool. Not expensive. Be certain you follow the correct re-torque sequence in the manual. If you don't, you can crack the heads.
rstroud is offline   Reply With Quote
