Old 07-13-2005, 10:12 PM
Cavaturbo Cavaturbo is offline
after the replacement of head gasket.....
what are the things that i should be concerned with so that the cars timing will be correct.....if the head, valve train, timing belt, cams and all the general stuffs that are requried are taken out? the car is a carburated. Basically, everything is taken out already. just not sure how to put it back in correctly. Thanks.
Old 07-13-2005, 11:52 PM
kcg795 kcg795 is offline
Re: after the replacement of head gasket.....
When you do stuff like this, it's always best to go by the repair manual and remove shit in order that it says to remove. The reassemble it in the order that it says to assemble it. Get a manual and study it and see which part goes where. I'm sure you'll figure it out sooner or later. Good luck.
