Go Back   Automotive Forums .com Car Chat > Chevrolet > Camaro | Firebird > Camaro Discussions
Old 07-07-2005, 11:20 AM   #1
Link85x
Question Counting Gears?/ How to find gear ratio?
How do i find the gear ratio of a rearend that is not on a car? Do i take the housing of the rear and count the teeth around the gear, or something along those lines?
87 IROC - R.I.P, and she will never be forgotten
90 RS - The beginning of a new era... I hope.
Link85x is offline   Reply With Quote
Old 07-07-2005, 01:22 PM   #2
Pewter'01SS
Pewter'01SS's Avatar
Count the number of teeth on the pinion gear and on the ring gear. Divide the number on the pinion into the number in the ring.
R.I.P. Andy...It was an honor to have known you.
'01 Camaro SS - SLP Short Throw Shifter, Granatelli Air Lid, blue neon underbody kit
'92 Chevy 1/2 ton 4X4 - 350 w/ 190,000 miles and in desperate need of a rebuild.
'86 Chevy S10 - 350 w/ 400 Turbo trans, B&M Pro-Ratchet, 4.56 Posi, 350 is gone and slowly being replaced.
Pewter'01SS is offline   Reply With Quote
Old 07-07-2005, 02:20 PM   #3
Link85x
Thanks.
Old 07-07-2005, 04:38 PM   #4
89IROC&RS
89IROC&RS's Avatar
Re: Counting Gears?/ How to find gear ratio?
or if you can read the casting number on the axle you can find out that way. but counting can work too
Chevrolet Camaro - I enjoy beating the hell out of people
http://www.automotiveforums.com/vbulletin/showthread.php?t=68052
89IROC&RS is offline   Reply With Quote
Old 07-07-2005, 04:45 PM   #5
Link85x
Where at on the axle? That way, i find the number tonight, post tomorrow. I won't have time to count until this weekend, but i want to find out sooner than later.
Old 07-07-2005, 05:02 PM   #6
89IROC&RS
89IROC&RS's Avatar
well its not like a clear 3.23 or anything, but the drive side axle tube on the side pointing to the front of the car, should have like a ten digit code on it, it might need a wire brush to take off surface grime to read it, but be gentle because the numbers may be hard to read.
Old 07-07-2005, 05:02 PM   #7
89IROC&RS
89IROC&RS's Avatar
also, do you have access to the car it came out of/???? where did you get the gears from?
Old 07-08-2005, 09:45 AM   #8
Link85x
No access to the car. If had the vin #, you'd be able to tell, right?
Old 07-08-2005, 07:22 PM   #9
89IROC&RS
89IROC&RS's Avatar
well, the dealership could, if you can get the VIN, you can go to the dealership, they can bring up the SPID lable for that car, which would include the rear end code.
