Go Back   Automotive Forums .com Car Chat > Buick > Roadmaster
Old 06-21-2005, 01:48 PM   #1
rnj
Send a message via MSN to rnj
HELP '92 estate brake light(on back glass) doesnt work
can anyone tell me how this light works??? as i see no wires running to it but do see contacts. the bulbs r fine, but they don't light up when i press the brake. Also, the plastic around the bulbs are burnt and melted, is this from the years or r they getting to hot?
rnj is offline   Reply With Quote
Old 06-23-2005, 11:52 PM   #2
jawnl
Re: HELP '92 estate brake light(on back glass) doesnt work
My personal experience with my '93 when that light doesn't come on is that the contacts in the casing need cleaning (cold climate = corrosion) - I carefully unbolt it from the glass and take it apart to clean those contacts. Sure seems like your bulbs got too hot - they're the right ones?
jawnl is offline   Reply With Quote
Old 06-29-2005, 11:56 PM   #3
rnj
I'm not sure, I think they are the wrong ones. I just bought this car about a month ago and I noticed that that brake light didn't work. So I went and bought some replacement bulbs and found that the contcts where pretty corroded and the bulbs were much bigger in circumference than the replacements I bought.
Old 07-03-2005, 02:01 PM   #4
Duncan1
You might need to clean the 2 spring loaded posts that stick out on top of the rear gate as well as the contact plate on the bottom of the glass. A non-working 3rd brake light might also affect your cruise control.
Good luck.
Duncan1 is offline   Reply With Quote
Old 07-04-2005, 02:24 PM   #5
rnj
Re: Re: HELP '92 estate brake light(on back glass) doesnt work
Good luck.
thanks, i cleaned contacts with wire brush works fine!!!
