Go Back   Automotive Forums .com Car Chat > Dodge > Neon | Plymouth Neon > 1st Gen 95-99
Old 06-10-2005, 09:11 PM   #1
johnqhitman
96 Neon Fuel Pump
Here is the deal, I recently bought a used 96 model Neon, SOHC with a steel fuel tank. I filled the tank up around noon and not 3 hours later the tank was down to 3/4 of a tank. I drove it only 15 miles from work which could not account for a fuel loss of some 3 gallons.
I noticed fuel a fuel smell and fuel dripping from underneath the right side rear seat. I removed a panel from under neath the car and saw fuel spilling from a ruptured rubber plug at the fuel pump. The fuel pump runs well, I just need this rubber plug (jury-rigged replacement is underway) and I do not want to shell out $150+ for a small rubber piece (which is the drain plug on the fuel pump I believe according to my manual).
Anyone know if I can buy them online? Or is a JY a better bet?
johnqhitman
johnqhitman is offline   Reply With Quote
Old 06-13-2005, 09:10 AM   #2
das2123
Tuning Neons since '97
Send a message via AIM to das2123 Send a message via Yahoo to das2123
I don't think I have seen parts from a fuel pump available to buy online or at a store. Junkyard is probably your best bet, or a new one.
das2123 is offline   Reply With Quote
Old 06-21-2005, 12:31 AM   #3
jcnj37
Re: 96 Neon Fuel Pump
johnqhitman
This is unreal..This very thing happened to me last week...No junk yard would sell me this little plug (which is the drain). I had lost a half a gallon before I got a 7/16 fuel hose...2 inches long and stuck a bolt in the end of it..I then placed a clamp on the bolt and one on the nipple of the fuel pump..and it has solved the problem....Good luck finding that little rubber piece...let us know
jcnj37 is offline   Reply With Quote
Old 06-21-2005, 03:37 AM   #4
palindromelol
johnqhitman,
I had the identical problem. I was unable to buy one at a junk yard or on-line. I could advise you to buy one at the dealer but that is abusively obvious and not helpful to you. Might I suggest jcn37 above described my solution as well as I could. It has worked well for 3 years. The objective is to keep the gas in, keep the dirt out, to not have another unplanned leak. You can cast a silicone seal in a latex finger. Cut off a latex glove finger tip. Fill it with silicone. slip a pen or a tube, the size of the fitting (a little smaller) into the goop. wait a day. A home made cap.
palindromelol is offline   Reply With Quote
