Go Back   Automotive Forums .com Car Chat > Pontiac > Trans Sport
Old 06-12-2005, 09:14 AM   #1
Viala
a/c break down
hello
who can tell me what i have to do to check the climatisation on my TS 92, I just get hot air when I switch on cold air!!!!!
thank's
Viala is offline   Reply With Quote
Old 06-12-2005, 10:00 AM   #2
yellowfiero
Re: a/c break down
Does the A/C clutch try to engage when called for?
You may just need a recharge.
yellowfiero is offline   Reply With Quote
Old 06-12-2005, 05:10 PM   #3
Viala
Re: Re: a/c break down
ok
how do I know when the a/c clutch engage
is there a special noise?
Thank's
Old 06-13-2005, 09:44 AM   #4
cdru
cdru's Avatar
Re: a/c break down
You should hear a click as well as hear the engine idle speed change slightly when it engages due to the extra load.
cdru is offline   Reply With Quote
Old 06-14-2005, 05:08 PM   #5
Bon@karl
Bon@karl's Avatar
Re: Re: Re: a/c break down
A click like "cdru" wrote, and you can see it in the Software... "A/C Request"... you can also test you clutch by tapping F4 and cursor up. Then you should hear the clutch clicking. Tab again F4 and yet use the cursor down key... you should hear the clutch again. Yet it's in normal position. To stop sending the signal by the software, only tab the "end "-Key.
Best regards
Mathias
http://www.pontiac-interface.de
Bon@karl is offline   Reply With Quote
Old 06-14-2005, 05:49 PM   #6
LMP
LMP's Avatar
Re: a/c break down
If you get HOT air when you switch to cold, I'd look for a problem with the diverter door acatuator.....
'93 Ponty Transport 3.8; 2011 SUzuki SX4 AWD (wife's) ; 2015 Sorento 2.4 AWD 1928 Graham Paige Model 629
I don't believe in miracles.
LMP is offline   Reply With Quote
Old 06-15-2005, 04:46 PM   #7
Viala
Bonjour
Can you tell me what is the diverter door acatuator.
Is it inside the car ( les commandes de circuits )
Merci de la réponse
Paul
Old 06-15-2005, 05:25 PM   #8
LMP
LMP's Avatar
Re: a/c break down
Yes..inside...well hidden. Photos here from Bonneville, but similar in transport manual.
www.avigex.ca/xport/MixerDoor1.jpg
www.avigex.ca/xport/MixerDoor2.jpg
Instruction for access to actuator (Transport manual):
Remove instrument panel upper trim pad assembly
REMOVE OR DISCONNECT:
-headlamp and wiper switch assembly screws
-cluster tim panel screws
-side window defogger grilles
-screws retaining IP trim pad
-open glove box
-I/P trim pad from seated position and from vehicle
Old 06-16-2005, 05:28 AM   #9
Viala
what a job to reach the actuator door!
Old 06-16-2005, 10:04 AM   #10
LMP
LMP's Avatar
Re: a/c break down
IN fact I did remove that trim pad a few times to access and remove the instrument cluster some time ago and it is quite easy. But I had not checked for access to the diverter door actuator at that time.
