Go Back   Automotive Forums .com Car Chat > Oldsmobile > Aurora
Old 06-08-2005, 02:37 PM   #1
MN Hunter
Unhappy Display thingy dangit
I'm at a lost on what to call it, but the display/control panel that shows you fuel mileage, when to change oil, trip meter, etc... has anyone had this work then not work then work.
I bought a 96 Aurora and it never worked, no biddy since I was just using it as a work rig, but one day on the way to work the display acutally worked, when I got home and shut off the car, fired it back up and it wasn't working.
So it's now a month later and all of a sudden the display and controls for all the options work... I'm thinking WTF.
Anyone have a clue on what to start looking at, sounds like a loose connector or something.
Any help would be great.... ride on!!!
MN Hunter is offline   Reply With Quote
Old 06-08-2005, 03:59 PM   #2
burntclayman666
Re: Display thingy dangit
sounds like the connecting points behind the cluster may be loose.
burntclayman666 is offline   Reply With Quote
Old 06-08-2005, 04:12 PM   #3
MN Hunter
BCM666.... the who'da what'da where'da... I'm used to working on my F150... this thing is a whole new animal for me.
Any help on where I could start looking for this, sorry, I'm a rookie!! HA!!
Old 06-08-2005, 08:11 PM   #4
baron1701
hunter...
This car is its own animal. Everything has its own way of doin. If the panel is damaged in any way, you can usually buy a new module on ebay pretty cheap. The ideal situation would be to carefully pull the section out of the dash and clean all the connectors w/ electrical cleaner or 91% rubbing alchohol. Either will do. I havent had to pull the unit out so if anyone has any tips please advise. The easiest way would seem to pull off the radio trimplate and move up from there.
baron1701 is offline   Reply With Quote
Old 06-10-2005, 05:38 PM   #5
Ridenour
GranddAmnit
Ridenour's Avatar
Send a message via MSN to Ridenour
I thought I'd just throw in incase it helps anyone - It's called an "Information center"
Ridenour is offline   Reply With Quote
Old 06-11-2005, 11:04 PM   #6
drrodder
drrodder's Avatar
Send a message via Yahoo to drrodder
I have this "Information Display' on my 98,800 mlie 1996 car doing the same thing along with turning on/off the temp gage, volts light, tration control light, cruise control light and dinging the alarm constantly. I just got it back form the Olds dealer (they used to be one) and the GM mechanics diagnostics are the computer module for this display and other parts are not comunicating with the other modules in the car. Currently I have 3 modules dead and at $500 - $800 per module the car isn't worth the money. Good luck on yours.
drrodder is offline   Reply With Quote
