some questions
Hey Guys
Im doing a ground up on wifes 1959 Morris Minor. All the rust was removed and rewelded and the car is painted with Omni epoxy primer (MP170). I will be spraying high build today (MP282 2k urethane) My problem is that Im not super experienced at the paint part and I keep getting different answers from pros that I ask. Hopefully you guys can help! My questions are: Do I need a sealer over this High build primer or can my colour go right over top? The girl at the paint shop said spray a light coat of Omni MP170 as a sealer. Also I plan on using a single stage paint. But Im clueless to what type. I want to use a hardener with it so I was going to use MAE acrylic Enamel w/ hardener. Is this good for a novice who will need to do a lot of fine sanding and buffing after or is there a better PPG topcoat to use? Any suggestions would be great! Matthew |
![]() Join Date: Jan 2004
Re: some questions
You can paint right over the sanded primer. Sealer is basically a primer but is shot right before spraying your color and does not have to be sanded. It is used primarily if you want to get the car all one color by sealing the whole thing, to get it a color closer to what you are spraying, or to prevent incompatability between paint on the car and what you are spraying. The mae I used on my car. It won't last as many years as a basecoat clearcoat job, but is less expensive. It can fade over time, because of the extra uv protection clearcoat has. If it is a solid color you are spraying you should be fine. A metallic would be harder to spray in single stage, and couldn't be wetsanded and buffed afterwards without a clearcoat. I used mae on my car about 4 years ago and still looks nice and glossy. It is white though, other colors like red fade more. White reflects most of the light and black absorbs it, so a darker color is going to absorb more uv rays and be likely to fade sooner.
Victorylap.20fr.com |
