Go Back   Automotive Forums .com Car Chat > Chevrolet > Venture
Old 11-25-2006, 08:39 PM   #1
thundermtx
Question BCM Wiring diagram
Looking for a wiring diagram for the BCM, specifically the door locks, exterior lights.............. am hooking up a remote start and need the info for the keyless entry side of the R.S.
thundermtx is offline   Reply With Quote
Old 11-26-2006, 08:11 PM   #2
83T/A98Blazer
Re: BCM Wiring diagram
What year Venture? I can get wiring diagrams for a 1997, I'll need to send them as an e-mail....
83T/A98Blazer is offline   Reply With Quote
Old 11-26-2006, 09:54 PM   #3
ponchonutty
ponchonutty's Avatar
Go to www.bulldogsecurity.com and it'll show you want you need to do for a Venture.
Silverado Ext. Cab 4x4 z71
Pioneer 4900mp
Orion P6.2 Componet sets front
Orion C63 Coax rear
DirectedVideo 9" all in one DVD with surround
2007 SATURN OUTLOOK AWD XR with full entertainment package
ponchonutty is offline   Reply With Quote
Old 11-26-2006, 10:21 PM   #4
thundermtx
Thanks for the web site. That helped a great plenty. Hoping the diagrams will be just as good.
Old 11-26-2006, 10:53 PM   #5
83T/A98Blazer
E-mail sent, hope they help!
Old 11-30-2006, 08:58 PM   #6
thundermtx
Talking Re: BCM Wiring diagram
Thanks for all of those, that's going to be a great help. If I could get more: ignition switch, rear power vent windows, windshield wipers? Thanks again.
Old 12-05-2006, 09:56 PM   #7
83T/A98Blazer
Sorry, haven't been here in a few days, still need those other diagrams?
Old 12-06-2006, 07:25 PM   #8
thundermtx
Whenever it's good for you; yes, I am still collecting diagrams. The R.S. is a Christmas present for my wife and am waiting on getting it from E-Bay.
Old 12-06-2006, 09:44 PM   #9
ponchonutty
Can I ask why you want the the rear power vent and wipers? The info from the link I gave should be more than plenty to get your RS to work. What RS are you going with?
Pioneer 4900mp
Orion C63 Coax rear
Old 12-06-2006, 10:04 PM   #10
thundermtx
Cool Re: BCM Wiring diagram
I'm going to close ALL windows when the doors are locked, and use the wipers to turn on the headlights when it's raining.
Old 12-08-2006, 07:29 PM   #11
83T/A98Blazer
More diagrams sent.
Old 12-09-2006, 08:28 AM   #12
ponchonutty
You do know that you'll need a window module to make them work with the remotes. On the wipers, I'd use a timer relay. If you don't, even if you hit your wipers for one second, the lights will come on and go off for one second. Instead, I used a module for the lights from Directed Electronics. Now, my lights have daytime running, turn on each time I use the wipers, and also come on by themselves when it gets dark enough out.
What year car? Make sure to be very carefull when probing around on a Venture van. These cars are riddled with enough electrical gremblins as they are now.
Here's for a 1998 van.
12volts red or red/white + ignition harness
Starter yellow + ignition harness
Second Starter
Ignition pink + ignition harness
Second Ignition white + ignition harness
Third Ignition
Accessory orange + ignition harness
Second Accessory
Keysense
Power Lock lt. blue - either kick panel or BCM
Notes: The BCM is located above the passenger side kick panel.
Power Unlock white - either kick panel or BCM
Lock Motor gray drivers kick panel or BCM
Unlock Motor tan drivers kick panel or BCM
Parking Lights+ brown light switch
Notes: Also located at the firewall connector.
Parking Lights-
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Door Trigger - BCM
Notes: There are three separate door trigger wires. They are: tan for the drivers door, dk. blue for the passenger door and liftgate, and orange for the sliding door(s). Use all 3 wires and diode isolate each.
Dome Supervision
Trunk/Hatch Pin see door trigger
Hood Pin
Trunk/Hatch Release lt. blue - passenger kick panel
Notes: To operate the sliding door, give a negative trigger to a lt. blue wire in a large black connector just below the BCM.
Power Sliding Door
Factory Alarm Arm red/black - either kick panel or BCM
Factory Alarm Disarm orange/black - either kick panel or BCM
Disarm No Unlock
Tachometer pur/wht or white ac
Notes: Main harness on the drivers side of engine on top of the manifold cover.
Wait to start
Brake Wire white + at switch
Parking Brake
Horn Trigger black - steering column
Pioneer 4900mp
Orion C63 Coax rear
Old 02-26-2007, 04:35 PM   #13
leo76
hi im new here and i think i have ground electric problem with my brake ligths, i change the circuit boards, the plugs that go in to the boards. still the same problem. i want to try to look if there is a short circuit in the wiring. but i dont know where the wires lead to any of you know if they go under the carpet. dont see them under the carriage.
leo76 is offline   Reply With Quote
Old 02-26-2007, 05:19 PM   #14
cjstew4
Did you change the wiring harness and plug that plugs into those rear taillight assembly mating, supposedly weatherproof plugs? If you did not, that's probably where your problem is. Unplug itand look for a slight burn in the middle wire/plug area. If so, you need to mark the location of each wire to the mating taillight prongs and then cut that bad plug/connector off, attach wire leads to each wire and plug them into the mating prong on the taillight plug. Once they all work, apply silicone weatherproof caulk to the whole assembly and let dry overnight. Works like a charm on 97' and saved me the expense of a new wire harness. Any ?s, email me at [email protected].
cjstew4 is offline   Reply With Quote
