Go Back   Automotive Forums Car Chat > Honda > Integra
Old 05-27-2005, 11:41 PM
atticus951 atticus951 is offline
Aem V2???
Ok so my car is an Acura integra and i just recently put a AEM v2 intake on and the CAI is low to the ground. Anyways it has been rainging out and i have a feeling some water has gotten in my car. But it hasnt affcted anything or at least not yet. Is there anything i can do to prevent hydrolock. I heard buting a K&N air filter would help does anyone know if you could tell me that would be great
Old 05-28-2005, 12:53 AM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
Re: Aem V2???
takes alot of water to hydro lock. i drove my old aem cai in rain, snow, and sun with never hydro locking. you should really be scared of those deep puddles what can you do?........................get a bypass valve which basically makes it pointless to go cai, or get rid of the cai
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
Old 05-28-2005, 05:52 PM
honda_racing101's Avatar
honda_racing101 honda_racing101 is offline
Send a message via AIM to honda_racing101 Send a message via MSN to honda_racing101 Send a message via Yahoo to honda_racing101
Re: Aem V2???
How does a by-pass valve make it useless to have a cai?
dSoc member #67
1995 Honda del Sol EG2 VTEC Milano Red. RIP :crook:
1994 Honda del Sol EG1 S-full VTEC conversion.
Buy my Del Sol parts!!
Old 05-28-2005, 06:08 PM
CivicSpoon's Avatar
CivicSpoon CivicSpoon is offline
There is no Spoon
Re: Aem V2???
Probably because it's like you're cutting an intake pipe in half and connecting it together with something made out of thick foam. So you're not getting the direct flow that you could with just the straight cai. Just look at the bypass and you'll see.
But water with a CAI can definently be a problem. A few years ago my friend was driving on the highway when it was raining, and he had to pull over and shut off the car because it was sputtering from water going up the pipe. You can also shut off the engine when you're going to go thru a big puddle (though not the smartest idea).
Old 05-29-2005, 01:27 AM
AF - Advisor
Re: Re: Aem V2???
you can either search or think about it
Old 05-30-2005, 12:24 PM
faygo_freak faygo_freak is offline
Send a message via AIM to faygo_freak
Re: Aem V2???
no bypass valves for AEM V2 unless custom made. and using a bypass valve does not make a CAI useless...it reduces the power produced by the CAI but its not just foam it uses some sort of a vacuum. check out AEMpower.com they got all the info on that stuff on the site
Old 05-30-2005, 01:42 PM
AF - Advisor
Re: Aem V2???
if you want some unbiased results? then dont search aem's site for their results on their own product
if the bypass valve only makes you lose a little bit of power, then, how much power does the cai give you to begin with not much different from a SRI is it
cut a piece of pipe in half and stick a filter on one end and a piece of foam in the cutted part. when it starts sucking, where does the air (or water if you wanna use a straw submerged in a cup of water) get sucked from? try that experiment and come back and report your results
ask yourself, what is the purpose of the cai? then ask yourself..................does the bypass valve eliminate the cai from performing what it was intended to do
Old 05-31-2005, 02:02 AM
Re: Aem V2???
94-01 Non-Vtec
peak with AEM V2: 127.7HP
peak stock baseline: 123.5HP
peak gain: 9.1HP @ 4250RPM
peak with AEM V2: 117.4 ft-lbs
peak stock baseline: 111.5 ft-lbs
peak gain: 11.3 ft-lbs @ 4250RPM
94-01 Non-Vtec
peak with AEM CAS: 127.4HP
peak gain: 10.1HP @ 4250RPM
peak with AEM CAS: 116.2 ft-lbs
peak gain: 12.5 ft-lbs @ 4250RPM
i dont know the numbers for a short ram cause they dont have dyno charts posted for it
they also have an article on their site by Sport Compact Car which explains much more about an air bypass valve then what im posting (http://www.sportcompactcarweb.com/te...ted/index.html) "Surprisingly simple in construction, but quite sophisticated in design, the AEM air-bypass valve sits upstream of the air filter and normally does nothing. If the filter gets submerged in water, however, there will be a slight vacuum in the pipe as the engine tries to suck the water up the pipe. This slight vacuum opens up 12 rubber flaps in the air-bypass valve, allowing the engine to breathe air through the bypass valve's small foam filter. When the water level drops, the vacuum goes away and the main filter supplies air again. No panic, no blown engine. How nice."
Old 05-31-2005, 03:06 AM
KrNxRaCer00's Avatar
KrNxRaCer00 KrNxRaCer00 is offline
Send a message via AIM to KrNxRaCer00 Send a message via Yahoo to KrNxRaCer00
Re: Aem V2???
except, for the bypass valve to actually work, the filter basically has to be submerged in water. now, you can get enough water into your motor to hydrolock it w/ out submerging your filter...
wow, great investment...
the safest thing you can do is simply use the CAI in the summer months (dry season) and then either put your stock air box back on, or purchase a SRI for the winter months (rain season.)
those 3-5 hp freed up by the CAI aren't really going to matter all that much during the raining season anyways (not going to matter much in a race to begin w/, but why even race in the rain?) so why risk it?
2003 Infiniti G35
99 Yamaha YZF-R6 (sold)
2000 Acura Integra Type R (sold)
1994 Acura Integra GSR (retired/sold)
Old 05-31-2005, 07:52 AM
Tano016 Tano016 is offline
Ive rad an aem cai installed on my gsr for 4 years now, never had a problem. Just use your common sense and dont go through large puddles!
Old 05-31-2005, 08:13 AM
Re: Aem V2???
will the AEM CAS sit as low to the ground as the V2 or will it stay up in the engine like a SRS
Old 05-31-2005, 03:43 PM
kornflakes28546's Avatar
kornflakes28546 kornflakes28546 is offline
Re: Aem V2???
The filter on the CAI is in the same spot on the V2 so they'd be the same
Old 06-01-2005, 01:16 AM
sameintheend01's Avatar
sameintheend01 sameintheend01 is offline
Send a message via AIM to sameintheend01
Re: Aem V2???
just let off the damn gass when u go through a puddle.
Clear Corners
Front and Rear Strut Bars
Cold Air Intake with K&N filter
Iridium Spark Plugs
High Performance Plug Wires
High Flow Cat (unistalled)
Cool high/low beam lights
All around slotted and AEM pads
