Go Back   Automotive Forums Car Chat > Nissan > General Discussion
Old 03-19-2005, 09:27 PM
JTARMY322 JTARMY322 is offline
Exclamation Cutting Out At 2500rpm Feel Like Rev Limiter?????
ALright WE have the exhaust in and the #1 O2 sensor has been moved to after the flex and before the cat on the downpipe, and the second one is in, we then reset the computer and took it for a ride, IT pulled ok through first and then in second somewhere around 5500RPM we got fuel cut, felt like the rev limiter, then after that it cuts down at
2500 RPM feels like it is hitting the rev limiter. EGR system is completely removed The only thing that is left is the Sensor that all of the EGR Vacumn lines goes too, there are three nipples on that sensor, one on the bottom that goes to the throttle body right before the butterfly, then there are two nipples on top, the top nipple is not attached to anything, normally it is attached to the BPT, the second one to the top of the sensor is attached where it normally goes on the intake hose, after the MAF and before the Throttle body. What the heck is going on. why is it cutting at 2500RPM other than because the ECU is cutting fuel. why is the ECU cutting fuel, Is it because the O2 Sensor has been moved so far down stream? or does it have something to do with the EGR system and the Charcoal cannister that is not hooked up, or does it have something to do with the EGR vacumn sensor? Please help???????
Old 05-16-2005, 08:56 AM
mmcleo11's Avatar
mmcleo11 mmcleo11 is offline
Re: Cutting Out At 2500rpm Feel Like Rev Limiter?????
2500rpm is the engine safety measure when you MAF sensor is seeing signals out of range... I could require a re-think of your setup...
check your air:fuel ratios to be sure.
N14 Pulsar
VQ35 conversion with major N/A upgrades, 6 spd FWD manual HLSD
18" Rims, big brake kit, Coil overs and freshly painted
Smashed Black VY SS Ute
The workhorse...
Twin turbo 5.7L LS1
Boyd Coddington 19" Turbine Wheels
AP Racing 4 Piston Brakes
Tein Coil over Suspension
HKS EVC 6 Boost Controller
PLX Devices DM-200 OBDII
Custom Front Mount Intercooler
