Old 05-17-2005, 10:58 PM
IROCU220 IROCU220 is offline
'85 iroc TPI with a big time engine miss
Hello. My problem is that my 8 cylinder engine is only working on 4 cylinders, the one whole side isnt firing. When I first step on the gas, the car stutters for a second before going. Its not the spark plugs or cables and I cannot find any pinched wires. Would this be a problem with the ECM? I been looking for another computer to try but the 6870 is so damn hard to find. Any places to get one? If thats even the problem I mean. I am confused.
Old 05-18-2005, 12:14 AM
CamarosRsweet94's Avatar
CamarosRsweet94 CamarosRsweet94 is offline
Re: '85 iroc TPI with a big time engine miss
What kind of ignition system does it have? Does it have seperate coils or distributors or whatever for each bank?
1994 3.4L Chevrolet Camaro - No more
2006 Hyundai Sonata
Old 05-18-2005, 01:13 AM
Morley Morley is offline
The ECM has no control over individual cylinders or banks. you have either, a bad cap, rotor, plugs or wires or bad (no) compression on all 4 cylinders on one side.
Old 05-18-2005, 08:39 AM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
I would go along the lines with Morley's last suggestion, something is common to the whole bank. Are you sure you have no spark on all 4 plugs? You verified this? I would suspect more like that banks fuel injecotrs aren't firing, that would be more likely.
As for the ECM, from one 85 owner to another, don't even bother with a another 85 ecm, upgrade to an 86. There are so many goof ball flaws with the 85 as it was the frist f-body TPI. There's no performance gains, just reliability.
Old 05-18-2005, 11:09 AM
Well, check all the basic things an engine needs, gas, spark, compression, and air. I'd say you can automatically rule out an air problem since the other bank runs fine. If you check for compression if one cylinder doesn't have compression I would guess the whole bank doesn't and would start looking into that. Fuel is a little more difficult to figure out, at least I'm not sure how to check it. I would put my money on a problem with spark since it is a whole group of cylinders.
2006 Hyundai Sonata
Old 05-18-2005, 11:19 AM
You have 2 inj fuses in the fuse block.inj 1 & inj 2..check them
