Go Back   Automotive Forums Car Chat > Chevrolet > S-10
Old 04-09-2005, 11:47 AM
jtiderencel jtiderencel is offline
Send a message via Yahoo to jtiderencel
Question S-10, won't go in gear
S-10. '86'
manual transmission
truck will not go in gear after starting engine. Bleeded the slave cylinder, still won't go in gear. how do you check the master cylinder and the slave cylinder to see if it is by-passing fluid. no leak under tranny or on floor board.
Old 04-09-2005, 12:10 PM
Ducaire Ducaire is offline
Re: S-10, won't go in gear
Sounds like you've got problems, mate. Sorry I can't help.
Old 04-09-2005, 03:06 PM
dmbrisket 51's Avatar
dmbrisket 51 dmbrisket 51 is offline
Send a message via AIM to dmbrisket 51
did it act up any b4 it went out or just die?
Old 04-09-2005, 07:05 PM
xtrememeasures10 xtrememeasures10 is offline
Send a message via AIM to xtrememeasures10
Re: Re: S-10, won't go in gear
My 97 did that last year. No warning at all. It was my slave and master cylinder leaking. so there wasnt enough pressure. You probably wont have any fluids leaking for a couple days but then it will start leaking all over. I personally dont know much about trannys so i took it 2 aamco. well good luck
Old 04-09-2005, 07:44 PM
16th hippy 16th hippy is offline
will it go into ANY gear, or just not first?. also, when running can you hear the clutch stop spinning when you depress the pedal, and hear it start spinning when you release the pedal? if you hear nothing at all like this, then chances are there is a clog in the line, or one of the two cylinders are bad, if not both. if it has fluid, and it's not leaking, then it has to be moving it somewhere, or not moving at all.. might also wanna check the line from master to slave to see if it got kinked somehow. hope this helps.
Disclaimer: I am not perfect, i may be wrong in my advice from time to time. Also note that any advice given is as is with no warranty whatsoever, and i have zero liability if you get hurt for not being safe while working on your vehicle.
Old 04-09-2005, 07:53 PM
toenailclippers toenailclippers is offline
Send a message via AIM to toenailclippers
hate it for ya
Old 04-09-2005, 10:47 PM
won't go in any grear. I don't know if clutch is spinning. lines are stright and in good shape. when bleeding the slave unit it flows all down my arm. I blead the unit like you bleed your brakes. some one told me you are supposed to open the bleeder valve, and just let fluid flow out. close the valve when flowing good. ???? don't sound right.
Old 04-10-2005, 07:54 AM
hopefully doing this while keeping a good eye on the master to keep fluid in it. make sure u have someone helping, and make sure they have the pedal ALL the way to the floor when u open the screw. you could have air in the line still. would try doign it again....and keep going until u are sure there is no more air in the lines.
Old 04-10-2005, 08:42 PM
lweford lweford is offline
clutch fork
I had this same problem. I replaced master cylinder & slave but didn't help. Finally pulled tranmission to replace clutch and found that the clutch fork, where it pivots, was almost wore in through. This wasn't allowing enough throw to fully ingage the clutch. Replaced clutch and fork and drives better than the day I bought it.
Old 04-15-2005, 01:52 AM
deadBird's Avatar
deadBird deadBird is offline
Simply bleeding it will temporarily fix your problem. If air got in there somehow, something else is obviously wrong.
Old 04-15-2005, 05:10 PM
bought a new slave unit, beld the shit, and fluid, out of it. got some gears, enough to get it to a shop. tell you what happens in the furture
jt
Old 04-18-2005, 04:36 PM
shop said the clutch is out. S-10 belongs to the neighbor when he gets it fixed, i'll tell you how much it costs him.
jt
Old 04-18-2005, 09:08 PM
willing to bet somewhere between $400 and $700 USD.
Old 05-13-2005, 11:14 PM
last report. cost 500+ to fix, they also fixed the exhaust leak. replaced clutch and all the goodies, ect. runs and shifts real good, smooth and easy.
thanks for the advise
talk to you guys the next time
jt
