Go Back   Automotive Forums .com Car Chat > Ford > Mustang > Mustang Talk
Old 05-08-2005, 08:33 PM   #1
SRamsey625
No Turn Signals on 92 GT
My turn signals went out yesterday, so naturally I'm thinking the flasher is out. I go down to Wally world get a new one. Get home, put it in and nothing. I ran a continuity on my turn signal lever. It checked good. Does anyone know where I go from here?
SRamsey625 is offline   Reply With Quote
Old 05-09-2005, 12:32 AM   #2
stang_racer20
stang_racer20's Avatar
Send a message via Yahoo to stang_racer20
Which side or both? Have you checked your bulbs. If one side is out, it causes the other(same side) to not work either. Also did you check the fuse after or before replacing the flasher. Finally, which is a common Ford problem, check the MFS(multi-function switch). In case you dont know thats the lever you press up/down when you turn the blinkers on, also contains the wipers, brights, etc. They have a tendency to not let certain functions work now and then.
92 Mustang GT, 347 Stroker(Forged Steel Crank/Rods-Balanced, Forged Alum Dished Pistons), B50 Block, Track Heat Intake, Twisted Wedge Heads w/ Stage 3 port/polish, 80mm C&L MAF, FMS 30# Inj., BBK AFPR, Trick Flow Stage 2 Cam, Trick Flow 1.6R Rockers, BBK EL-CC Headers, MAC O.R. H-Pipe, Flowmaster Cat-Back, Accufab 75mm TB, MAC CAI, BBK Pulleys, Griffin Alum Radiator, Mark 8 Fan, MSD Pro-Billet Distributor; AOD, Dynamic 3300 L-U Converter, B&M Trans Cooler; 3:73 gears.
stang_racer20 is offline   Reply With Quote
Old 05-09-2005, 07:41 PM   #3
SRamsey625
Re: No Turn Signals on 92 GT
Thanks. Just shortly after I posted this, I went back to troubleshooting a little bit. It seems that the problem was the wire coming from the connector block that goes to the flasher had come loose and slipped back into the block. A little super glue did the trick. I only thought to check this because I had the same problem with the headlights believing that my switch had gone out. Took me about a week to figure it out then. Thanks for your help though........
Old 05-09-2005, 11:13 PM   #4
2crunk
2crunk's Avatar
It seems alot of 87-93 mustangs have turn signal switch problems, has there ever been a recall?
Check out more pics and info on my Stang at: http://www.cardomain.com/profile/2crunk
Rest In Peace Hypsi87, you'll be missed.
2crunk is offline   Reply With Quote
Old 05-10-2005, 11:54 AM   #5
importeater5_0
Send a message via AIM to importeater5_0
how much does a new multi function switch cost, because i think mine is all mest up, a while ago my headlights didnt work and my dad did something to fix them but because of what he did my high beams dont work, and now my blinkers are mest up and dont blink they just stay solid
importeater5_0 is offline   Reply With Quote
