Go Back   Automotive Forums Car Chat > Ford > Windstar
Old 05-02-2005, 09:28 PM
sperduton sperduton is offline
axle shaft removal.
I need to pull the passenger axle out of my 2000 windstar. After I pull everything off, steering knuckle, etc, should the shaft just pull out of the trans, or is there some kind of clip that I need to remove inside the trans?
I'm thinking I just need to pry between the cv joint and the trans and it should pop out.
Thanks,
Nick
Old 05-03-2005, 08:23 AM
12Ounce 12Ounce is offline
Re: axle shaft removal.
Your are correct! The clip is inside the tranny ... on the shaft itself ... don't worry, it will come out with the shaft. Pry away!
