Old 04-25-2005, 09:10 PM   #1
HandyRandyfl
92 chevy van 5.0 bad surging at idle and highway
Need help no power at take off bad surging. Replaced O2 Senser, Map Sensor, EGR Valve, Hei Module, Ingnition Coil, Pluggs , Wires, cap, rotor, fuel filter air filter, pcv valve, cat. Check all vac hoses . checked fuel pressure between speeks . check timing. check throttle body for leaks . running out of thoughts . any suggestions will be very helpful
HandyRandyfl is offline   Reply With Quote
Old 05-04-2005, 10:36 AM   #2
smokey041369
Re: 92 chevy van 5.0 bad surging at idle and highway
goto the auto parts store and have them put the code reader on it
if it doesn't tell on the print out what the codes mean post them here and we can help you more
smokey041369 is offline   Reply With Quote
