Old 04-15-2005, 07:59 AM
wonword wonword is offline
Send a message via AIM to wonword
FlyWheel
Does anybody know how to prevent the flywheel from moving without the specialized tool? I tries already a crow bar and such, but the bolts are torqued down to hard it just moves no matted what? I need to take the flywheel off to get it remachined, so any ideas would be great!!
Thanks,
John
94' Nissan Altima SE
K&N High Flow Air Filter
Greddy St Exhaust
OBX Header
Short Throw Shifter
Extreme Performance Clutch
68' AMC Abassador
Chevy 350
TH 350 Tranny
Headers
Dual Exhaust
1999 Suzuki GSX-R 600
Yellow/Black
Yoshimura Exhaust
http://members.cardomain.com/wonword
Old 04-15-2005, 11:32 AM
RandomTask's Avatar
RandomTask RandomTask is offline
Banned
Re: FlyWheel
easiest thing I could think about is an impact gun, since its more of a hit of 600ft lbs rather than a consistent 200 ft/lbs they break loose a lot easier. If the impact gun is out of your budget, try wedging a pry bar into the teeth and against something, have someone hold the pry bar, then go to town...
Good Luck!
Old 04-15-2005, 12:26 PM
Re: FlyWheel
Hey Randomtask,
Thanks for the reply, I tried the pry bar and wedgeing it and everything, it just doesnt work!! Wouldn't the impact gun just turn the flywheel also?
Thanks,
John
Greddy St Exhaust
OBX Header
Short Throw Shifter
68' AMC Abassador
Chevy 350
TH 350 Tranny
Headers
Dual Exhaust
Yellow/Black
Yoshimura Exhaust
Old 04-15-2005, 03:04 PM
curtis73's Avatar
curtis73 curtis73 is offline
Professional Ninja Killer
Re: FlyWheel
Nope. Impact wreches hit pulses of torque. Its the same reason why when they change your tires, they can get the lug nuts off with the wheels up in the air. It doesn't even turn the free-spinning wheels.
Dragging people kicking and screaming into the enlightenment.
Old 04-15-2005, 03:08 PM
Re: FlyWheel
Sweet, I thought they would turn the fly wheel as well. I'll go out and buy a air compressor this weekend, what size compressor in gallons would run an impact to it's max power? Another thing, does anybody know of somewhere that remachines flywheels, and how much?
Thanks Again for thr replies,
John
Greddy St Exhaust
OBX Header
Short Throw Shifter
68' AMC Abassador
Chevy 350
TH 350 Tranny
Headers
Dual Exhaust
Yellow/Black
Yoshimura Exhaust
Old 04-15-2005, 06:22 PM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
Re: FlyWheel
Have you checked the flywheel dosn't have a hole through it, with a corrosponding point in the block that you can use to jam it with?
Some do, some don't.
