Old 04-08-2005, 09:40 PM
blazer88 blazer88 is offline
4.3 idling problem
OK guys, I have searched before I am posting a question here. I have a 4.3 TBI in a 88 S10 blazer. The other morning the truck would not start without giving it gas and would not idle on its own. When warm , the truck would idle, but about 500 rpm below normal and then sometimes would shut down. When driving the vehicle the response is there, but at idle it is not.
I have checked the computer for codes but none are there.
Is it possibly the EGR valve?
Is it the TPS
Is it the IAc?
WOuld any of the above be bad and not give any codes?
Any assistance is appreciated
Thanks in advance
Old 04-08-2005, 10:12 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: 4.3 idling problem
Ever done a tuneup?
Did you clean the IAC?
Old 04-09-2005, 01:32 AM
nalgman's Avatar
nalgman nalgman is offline
Is it the TPS
Is it the IAc?
Thanks in advance
OKOK
i have a 4.3 1990 TBI and one time i had these problems.
first of all.. assuming you have good wires,sparkplugsand thes kind of things.
if you havin' trouble starting or when idle it's like shakin' a little and sometimes shut off.. well..
check the fuel injectors.
quit the plate and the air filter and turn ON the TRUCK and see the two injectors working..
you should see sprayin gas in this form /\ DOWN. if you only see drops or one injector more power than other , ok you have problems.
i hope this help
Nalgamandapio's place
Old 04-10-2005, 11:05 AM
skaterkid134 skaterkid134 is offline
try checking your wires and your timing belt its possible its your fuel pump too
Old 04-11-2005, 07:16 PM
Thanks for all the replies. The problem was water in the gas system.
Thanks again
