Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 04-11-2005, 08:12 PM
wildbunch wildbunch is offline
Code 44
I own a 95 chevy suburban. The service engine light has come on and the trouble code is for lean exhaust (44). The engine stalls out while idleing and hesitates during acceleration. I have change the plugs, wires, distb. cap and rotar, the o2 sensor and fuel filter. The mechanic had it all day and the timing chain and timing is fine. All sensors are testing properly. Fuel pump is good. Fuel Pressure is good. Hose are good. What can be causing this problem? I am ready to pull my hair out.
Old 04-12-2005, 08:53 PM
amac209 amac209 is offline
Send a message via MSN to amac209
Re: Code 44
clogged fuel injetors, fuel pressure regulator not working(common problem spring gets weak& rusty) vacuum leak somewhere. another thing just because fuel pressure checks out at idle doesn't mean it's good while under heavy load.
Old 04-13-2005, 12:44 AM
Eggert Eggert is offline
Re: Code 44
Thanks, amac209 for the good info.
Here is something additional from http://www.syty.org/old/d&e-code44.html
TEST DESCRIPTION:
Numbers below refer to circled numbers on the diagnostic chart.
This test checks the oxygen sensor's heating element. The heating element resistance should be 3.5 ohms at 20'C (68'F) or 14 ohms at 350'C (562'F).
Code 44 is set when the oxygen (02) sensor signal voltage on CKT 412
remains below .2 volt for 2 minutes and the fuel system is operating in "Closed Loop."
DIAGNOSTIC AIDS:
Using the Tech I diagnostic computer "Scan" tool, observe the block learn values at different rpm and air flow conditions. The "Scan" tool also displays the block cells, so the block learn values can be checked in each of the cells to determine when the Code 44 may have been set. If the conditions for Code 44 or Code 64 exist, the block learn values will be around 150.
O2 Sensor Wire. Sensor pigtail may be mispositioned and contacting the exhaust manifold.
Check for intermittent ground in wire between connector and sensor.
Poor connection at oxygen (02) sensor ground wire.
Lean Injector(s). Perform injector balance test CHART C-2A.
Fuel Contamination. Water, even in small amounts, near the in-tank fuel pump inlet can be delivered to the injectors. The water causes a lean exhaust and can set a Code 44 or Code 64.
Fuel Pressure. System will be lean if pressure is too low. It may be necessary to monitor fuel pressure while driving the car at various road speeds and/or loads to confirm. Refer to Fuel System Diagnosis CHART A-7.
Exhaust Leaks. If there is an exhaust leak, the engine can cause outside air to be pulled into the exhaust and past the sensor. Vacuum or crankcase leaks can cause a lean condition.
If the above are OK, it is a faulty oxygen sensor.
Take care, Eggert
