Old 04-05-2005, 08:27 PM
contran contran is offline
pls hlp,I'm no mech. 88 PGMFI accessing PCV tube at crankcase?
I disconnected the PCV Valve tube from the PCV Valve and cannot detect
any air flow so I think the tube may be blocked. Does this sound
reasonable?
I want to clean the tube by removing it and knocking any debris out of
it but I can't unfasten the tube from the crankcase. By sliding my
hand under the (I think they're called intake manifold branches) I can just
barely touch the fastener with a finger after I remove some other
tube/wire mounts. The fastener looks like a band of steal 3/8ths wide
and I can feel two prongs(one thin and one wide) on the underside of
the fastener about 1/4 inch apart.
Can someone please tell me how to access and remove this item?
thanks a lot
Eric
Also:
The valve sits on top imbedded in one of the intake manifold
branches so there is just 1 tube
from the valve to the engine and its very hard to reach.
PS: the valve itself looks like this,
http://img.eautopartscatalog.c...V.JPG
Oh yeah, I'm puffing smoke badly so trying to fix that before aircare.
thanks a lot
Eric
Old 04-05-2005, 08:30 PM
Scott82 Scott82 is offline
Re: pls hlp,I'm no mech. 88 PGMFI accessing PCV tube at crankcase?
long needle nose pliers should do the trick. if not, needle nose vise grips are handy cause you can lock the clamp open to work it loose.
Old 04-05-2005, 08:34 PM
91civicDXdude's Avatar
91civicDXdude 91civicDXdude is offline
Send a message via MSN to 91civicDXdude
there should only be air coming out if you have a lot of blowby. the PCV works on vacuum.. i.e. engine vacuum sucks through the PCV valve instead of block pressure pushing through it like you would think.
What makes you think you should be spoonfed?
http://4thgencivic0.tripod.com
90civicrider's Avatar
90civicrider 90civicrider is offline
www.DecepticonRacing.com
chances are that hose is stuck on there.. Move the little metal clip up towards the center of the hose. Then yank, wiggle, and do a little cursing to get that hose off
||JEFF| |
Candy Orange 1990 Honda Civic H/B
