Go Back   Automotive Forums Car Chat > Pontiac > Montana/Montana SV6
Old 03-31-2005, 08:48 PM
markqc markqc is offline
power window wiring
Anyone have the wiring diagram for the passenger power window switch. Trying to trouble shoot the window switch and there are about 7 wires.
Thanks,
MArk
Old 04-01-2005, 08:21 AM
sparky65 sparky65 is offline
diagram
sent you a PM
as far as i can tell there is a gray and blk wire for the light on the switch.
the brn wire feeds the switch (hot in run) and then there are two other blk wires one for open another for close that goes to the motors. one of these blk wires becomes BRN and if you have seven wires that is becouse each motor is run sepretly to the back. So the BRN and the BLK both split with a BRN and a BLK going to the left and a BRN and a BLK to the right.
If the switch is in the open position the BRN is hot, if in the close the BLK is hot.
Steve
2000 Pontiac Montana Ext
2009 Ford Mustang GT
1967 Ford Mustang coupe
Old 04-01-2005, 01:45 PM
Thanks for your reply. I took a closer look at the connector and wires and found the following.
One side of the connector is marked A, B, C. D and has 4 wires
A is Dark Blue
B is Grey (Thinner wire)
C is Black
D is Beige
The other side of the connector is marked E, F, G
E & F both have Brown wires
G is light Blue
This is the passenger door window switch. Why so many wires?
Thanks,
Mark
