| Car Audio Do you live in your car? Then you need to be able to listen to some high-quality music. |
why is my system doing this??? help,plzzz!!!
hers my problem my subs just stoped working. the power light is on and the protection light was off. i have 2 400w subs hooked up to a 600w amp. what could be the problem??? i checked the fuse-good, power-good, ground-good,REM-good, and subs hooked up to the amp are good. what else could thire be im missing. I am new to the audio world but when i took my 12v off of my amp the power light still worked??? could i have sumthin hooked up wrong??? i dont know but if you guys could help me out that would be great
Re: why is my system doing this??? help,plzzz!!!
You could have fried the subs or the amp. Most amps will still power up when they're fried. Make sure to recheck all connections.
2002 Ford Explorer Limited D31 yellow top Kenwood DDX-7017 2 Ascendant Audio Avalanche 18's 13 cuft NET ported box tuned to 27hz Autotek Mean Machine MX3000.1 Ascendant Audio Arco component set Orion 275SX (Mids) PPI Art Series A200 (tweets) Poly Mids for rear fill to come soon. |
how will i know if i fried the amp
could i have screwed sumin up on my cd player. or fired a fuse i dint check in the car. are their other possibilities of what could of whent wrong. any body else know.
If the ground wire is removed often the power light will remain on, but wont have power to actually work,
check your wiring to make sure you hooked up ground to body, and + to battery. My buddy had a problem where the shop he took his amp to said that the amp was wired wrong from the factory with + and ground switched internally (I doubted there conclusion) Check your cd player fuse, but if it is still working I doubt you messed it up at all, Remote wire could be to blame re-check this connection. The way I would check to see if you fried the amp is pull it from the car, jumper new wires to +, ground, and remote, hook up different sub. Change the whole set-up going to and from the amp. if you dont get power from it, obviously the amp is to blame. This is easy to do if you have a buddy with a nice working system also hooked up, just pull his amp wires, hook them up to yours, and see if his system is working.
It's beautifully destructive isn't it, '97 Maroon SL1- Bored Throttle Body, Knife Edged Throttle Plate, Short Ram Intake 3" Cone Filter, Flip Flop Trunk, Red Enameled Engine, Interior & Exterior Painting Mods, 4" Burnt Tip Muffler, DRLs ON A SWITCH!, "Rims", Seat Covers, And A Stereo System Thats Too Good!, Other various mods and detailing... |
Yea your RCA outputs could be fried..... smell your amp see if it stanks if so its forshore bad..... if is smells good it could still be messed up but you'd need to open it up or have a multimeter....... to check the subs just push the middle of the cones you'll be able to tell if they're blown.
like stang said, could be the rcas or even the preout itself. i'd pull the h/u and check to see it anything doesn't look right
(2) RE SX 15s (www.reaudio.com) ~6.5^3 net @ 35 Hz (polyfilled to increse vol. & lower tuning to 32 Hz) (2) eD Nine.1s (www.edesignaudio.com) 1 Optima yellow top (www.optimabatteries.com) 1 Optima red top 200 amp alt (www.dbelectrical.com) eDead V1SE2 250 sq ft Big 3 (1/0 awg) Pioneer DEH-P650 (www.pioneerelectronics.com) Infinity Reference 5 1/4 comps (www.infinitysystems.com Infinity Kappa 6x9s MTX Thunder 3404 Power Acoustik TFT/LCD Pyle DVD/CD/MP3/WAV/WMA player |
be careful that your grounds are good on power amp, if the ground becomes insufficient - it may try and use the RCA sheilds as a ground. This will of course most likely damage the preamp output satge of the next unit upstream in the signal path (eq, xover, headunit, etc ...)
