I picked up a '95 TransSport to replace my pickup.
The only problem I have discovered so far is the power mirrors don't work. I checked the wiring with my meter and it seems to be a bad ground, but where? Also would anyone know if there is a relay for them and where it is located? Otherwise I believe I am going to really enjoy the vehicle. Drove it over the weekend and it rides well, runs excellent. LJ |
Re: Hi, Just got a 1995 TransSport
NO relay. 12V through CTSY fuse (15A) in fuse block, but a lot of other features would not work: door locks, and others. ANd ground is also common to all these same accessory. So...I'd check at the switch: the switch provides both hot and ground contacts to the motors, so if you do a voltage feed check, do not use body ground as a reference point.
'93 Ponty Transport 3.8; 2011 SUzuki SX4 AWD (wife's) ; 2015 Sorento 2.4 AWD 1928 Graham Paige Model 629 I don't believe in miracles. |
