Go Back   Automotive Forums .com Car Chat > Ford > Crown Victoria
Old 02-27-2005, 04:00 AM   #1
magmgud
Question Headlight switch?
My 1993 LX seems to have a problem with the headlight switch. I have to hit a precise spot when pulling out the switch to get the headlights on. And sometimes when I'm driving the headlights go out. Then I have to find that precise spot again to get them on.
Do you guys think the Headlight Switch has gone bad or has it something to do with some relay thingies?
Does someone here know where I can get a new Headlight Swich on the internet?
Thanks! magmgud
magmgud is offline   Reply With Quote
Old 03-02-2005, 10:41 AM   #2
way2old
TOKEN HILLBILLY
way2old's Avatar
Sounds like the switch to me. Ford has a relay in the switch itself. If you have to pull the knob to a certain position, the switch is probably bad. Go to http://www.motorcraft.com/default.asp?T=3&PageID=0 a Ford parts site. You may be able to find it cheaper at an aftermarket place.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
way2old is offline   Reply With Quote
Old 03-02-2005, 05:28 PM   #3
magmgud
Alright, thanks!
Old 03-10-2005, 03:40 PM   #4
cobradude360
cobradude360's Avatar
Send a message via AIM to cobradude360
how do u remove the old one?
THE 92 grand marquis LS M75 with the 281 romeo v8 u cant mess with that
MODS: dynomax bullit exhaust, custom intake, polished upper plenum, 180T-stat, accel coil packs and platnum plugs
also 2005 crysler sebring sedan walter p crysler edition yea its got the 2.4 pics comin soon
cobradude360 is offline   Reply With Quote
Old 03-10-2005, 07:24 PM   #5
way2old
TOKEN HILLBILLY
way2old's Avatar
If it is the pull type, pull all the way out. See if there is a little latch that needs to be pushed toward the dash. Then pull rod out. There is a nut that holds the switch in the dash. Remove nut and remove switch from inside the dash. If it is rotary, pull knob off. Pop trim around switch off and remove switch. Not sure which type you have.
