I purchased my 98 Lumina used and have not had a problem until now. My brake lights do not work, I checked the bulbs and they are fine. Looking in the fuse box next, I noticed the fuse that was for my brake lights had a red wire running into it. There was another wire running into another of the fuses. What the heck are those wires doing there? The fuses were fine, and I can't figure out what the porb. is. I'm not very knowlegeable about cars, so I need HELP! because I would like to be at least a little informed before I get hosed by a mechanic. PLEASE HELP!!!
If your lower brake lights do not work, but the high-mounted one does, it may be your multi-function switch. That part is in the steering column and cost about $200 to repair. I had to replace one at about 30,000 miles.
I had the same problem on my '98 Lumina, and I've read a ton of threads about this. So I'm posting to let you know there's a cheaper solution than a new turn signal switch:
Being an electrical engineering college student, I knew there was an easy and inexpensive fix for this. I've designed a circuit which corrects the worn switch behavior. Installation takes about 15 minutes - cut 3 wires (brake signal and turn signal wires) and insert them into the screw terminals on the circuit board. The board (about 1.5" x 2.5" x 0.75") rests near the base of the steering column, hidden by the panel. If anyone else is interested in this fix, let me know. I'll sell a built and tested circuit board, along with installation instructions and pictures, for $30. Email me at jcward @ mines . edu (remove the spaces) Cheers, -Jeff |
Update:
I've set up a website detailing my circuit board, installation instructions, and lots of other info. Check it out, at: http://www.familyhomepage.net/lumina/brake_lights.htm Note that this is my home server, so it may be a touch slow. Let me know if you have trouble with it. Thanks, -Jeff |
Lactose the Intolerant
![]() Join Date: Aug 2004
Re: '98 Lumina Brake Lights
"The General" might send a couple of goons to your house to break your legs, if you keep muscling in on their "build a crappy component and then charge a fortune to fix it" racket. LOL! Cool fix! If I have that problem, I'll be ordering one.
#6 | ||
Re: Re: '98 Lumina Brake Lights
