how do i remove the bed on my 89 c1500?
I heard its really easy to do, something like 9 bolts you take out i guess. Im just wondering this to take some weight off the truck, like anything that can make it lighter or get better mpg with im trying. It's not illegal to drive around without the bed on either right?
![]() 89 Chevy C1500 - Over 305,000 miles on her but still going strong. Cut off cat/straight pipe. Flo-Pro muffler. (Flowmaster soon) Dual 3" tips. custom intake. chrome valve covers. uhhh and im poor so thats all haha. Friggin truck costs more to keep alive than I do. (4ishMPG no joke) Wait, let me get this straight...Your honda has 1.6 liters, but my bottle of Mountain Dew has 2!? |
#2 | ||
![]() Join Date: Jan 2005
Re: how do i remove the bed on my 89 c1500?
To answer your original question there should only be about six bolts holding the bed to the frame. then there is also the wire harness to the taillights. You will want to save that so you can hook the lights back up if you remove the bed. |
Also an easy thing to forget is the gas filler neck. You have to get it and the ground wire out of the way too!
![]() Join Date: Dec 2004
I took the bed off of my 89 and I believe there were 8 bolts, the wiring harness for the lights, and the filler neck. But be sure to look out for the ground cable from the filler to the bed.
I do not know if it is legal or not to remove the bed, but they are not very heavy. My father and I just lifted it off the truck. So it can not weigh that much. As for the gas mileage, be sure to check the injecters to make sure they are working correctly, check the coil, and make sure the valve in the air intake works properly. I had problems with these and it helped my gas mileage. |
Removing the bed wouldn't improve the gas mileage on a truck much, it's a VERY small percaentage of the total weight. If you were removing that much weight from a civic or something, it might make a noticeable difference. As Austin8214 said, try removing the tailgate.
'04 Cavalier coupe M/T 2.2 Ecotec Supercharged 14 PSI boost, charge air cooler, 42# injectors Tuned with HP Tuners Poly engine/trans/control arm bushings Self built and self programmed progressive methanol injection system |
