Go Back   Automotive Forums .com Car Chat > Chevrolet > Cavalier > Performance
Performance Anything you ever wanted to know about boosting the performance of your Cavalier.
Old 02-27-2005, 10:07 AM   #1
WalkinKrookd
Swap
What are some good and relatively cheap engine swaps for an 02 Cavalier with a 2.2L Eco?
WalkinKrookd is offline   Reply With Quote
Old 02-28-2005, 02:06 AM   #2
noshun
noshun's Avatar
Re: Swap
You're best sticking wih the EcoTec unless you plan to go crazy. It's a nice light engine and there are more and more tuning products for it everyday! depends on what you want to do with the car etc etc!
Red Z24 = Dead, 03 2 door = 15.5 with no traction. low 15's here i come
'Never forget Grasshopper, Not speed, smile!'
noshun is offline   Reply With Quote
Old 02-28-2005, 06:48 AM   #3
WalkinKrookd
I've got a friend with a 95 Accord with an H22 dropped in it. No other mods except a cool air intake. And he said I would never be able to beat him. So I'm trying to prove him wrong.
Would I have to do any body work to drop in a supercharged 3.8? Or just some re-enforced engine mounts?
Old 02-28-2005, 10:31 AM   #4
noshun
noshun's Avatar
Re: Swap
complete custom mounts all round. The mount points are completely different. Poss relocate battery to trunk, pcm, wiring loom etc!
Although just putting forced induction on your motor up to about 7psi with stock internals would beat him! He's probably running about 175-180 hp! with 7psi you could hit 190! And you car weighs less!
Old 02-28-2005, 11:19 AM   #5
Classicrocjunkie
Lifted GMT-360!
Classicrocjunkie's Avatar
Send a message via AIM to Classicrocjunkie
Re: Swap
.... thats about it. Stick with what you have or plan on dropping alot of loot.
Please don't PM me with your J-body Issues. Post appropriately in the forums,
and I will toss my opinion in your thread if I have anything to help. - Thanks!
2006 Chevrolet Trailblazer
2010 Glastron GT 205XL
Classicrocjunkie is offline   Reply With Quote
Old 02-28-2005, 03:52 PM   #6
ImSoYesterday
Send a message via ICQ to ImSoYesterday Send a message via AIM to ImSoYesterday Send a message via MSN to ImSoYesterday Send a message via Yahoo to ImSoYesterday
Re: Swap
2.3 High output if you can find one.. some 180 horse out of it... YAY! umm. but good luck.
ImSoYesterday is offline   Reply With Quote
Old 02-28-2005, 06:05 PM   #7
noshun
noshun's Avatar
Re: Re: Swap
some w-41 were 190hp but the 2.3 weren't the most reliable motors and the blocks were weak which is why they reduced the bore and increased the stoke for the LD9 making it MUCH stronger.
Old 02-28-2005, 08:20 PM   #8
WalkinKrookd
Ok I understand mounts and wiring loom, but what is pcm?
Could I beat him without turbo? I mean if I got a gasket match, intake, intake mani, headers and cat back. Would that do the job?
Old 02-28-2005, 08:24 PM   #9
WalkinKrookd
Did I mention I have little cash flow...I want to do this shit right, but I also have little knowledge. And I'm eager to learn.
Old 02-28-2005, 08:52 PM   #10
noshun
noshun's Avatar
Re: Swap
if you have little cash flow you'll want to strip your interior. a turbo would help you beat him but will run about $2500-$3000 depending on what you want powerwise. but can be more. intake, exhaust. yeah you'll get some more power, the accord weight more anyhow so you don't need to match his power but if you did you'd win! unless he has manual and you auto! The PCM is the engine management system, computer, engine controld module and stands for Powertrain Control Module. What do you mean by gasket match? do you mean match porting?
Old 02-28-2005, 10:07 PM   #11
WalkinKrookd
We both have manuals. From my understanding a gasket match is similar to port and polish but not as extreme. They say it generally adds 15-20hp. So is a PCM like an ECU or are they different?
Old 02-28-2005, 10:36 PM   #12
noshun
noshun's Avatar
Re: Swap
They are the same thing but different car mfg call them different things for different years. b4 95 they were ECM but then became PCMs. I think you mean match porting which is where the intake port and manifold are made to be as seamless as possible so it doesn't disrupt the airflow. The same for the exhaust side. the intake port is usually a little smaller than the appropriate manifold.
Old 03-06-2005, 02:27 PM   #13
WalkinKrookd
Re: Re: Swap
What are some possibel draw backs to port matching. I mean is it going to make my car suck gas or are there no real draw backs? Does it really matter if I get a crate engine or just swap for a used?
Old 03-06-2005, 05:57 PM   #14
noshun
noshun's Avatar
Re: Re: Re: Swap
it will do nothing but good things! It just smooths the intake flow!
Old 03-06-2005, 11:28 PM   #15
Classicrocjunkie
Lifted GMT-360!
Re: Swap
Some people i have talked to saying the polishing part dosn't really help them out alot. With an unsmooth bore the disturbance in the air allows for a better mixture. But there has been no actualy finding dyno wise on either or. But porting does make a difference.
