Go Back   Automotive Forums .com Car Chat > BMW > 3 Series
Old 01-10-2005, 09:57 AM   #1
garymyron
Question How do I Turn the Service light off
I took my 318 is auto to a local garage for a service but they could not cancel the service light.
Is there a sequence which will do this. I know other manufacturers enable cancelation by a series of actions like using the egnition key co-ordinated with the trip reset button.
Does anyone know if this is so with BMWs.
Gary
garymyron is offline   Reply With Quote
Old 01-10-2005, 12:50 PM   #2
sparticus1262
you didn't say what yr your car was? I used this method for my e30 1991 318is to reset the lites.
http://www.noren.com/bmw/e30reset.htm
sparticus1262 is offline   Reply With Quote
Old 03-04-2005, 05:15 PM   #3
joesbmw
Re: Turn the Service light off
as far as i know all faults can be reset with a OBD tool cheap if 1994 or below $130 and above if newer
joesbmw is offline   Reply With Quote
Old 03-05-2005, 12:28 AM   #4
jzanutto
Service light
Gary, it is very easy to reset, using a simple piece of wire and the procedure that was listed in the 2nd posting to your question. But you must make sure no other lights are on- your service light came on for a reason, it could just be because of an oil change interval, but it could also be because of something like your coolant level was low. My car had a bad coolant level sensor, so the coolant light was on- I had to clear that first, then perform the reset procedure. Good luck.
JZ
jzanutto is offline   Reply With Quote
Old 03-07-2005, 11:43 AM   #5
Skycity_BMW
Skycity_BMW's Avatar
Send a message via Yahoo to Skycity_BMW
Exclamation Re: Turn the Service light off
If it's a E36 . . . . here ya go . . . .
http://www.unofficialbmw.com/e36/ele...ce_lights.html
Skycity_BMW is offline   Reply With Quote
