I need to know how many ft/lb tq to tighten the head, intake manifold and exhaust manifold on a D15b vtec. Im thinking it should be the same as the Z6 motor. Also just as important…I use all the gaskets and timing belt from the 92-95 z6 …right?
_________________________________http://VelocityFactor.com________________________________ 1990 si hatch b20b si tranny megan race header 2.5 custom exhaust 50 shot integra da rear disk (w/ 4040 valve) powerslot rotors and barded lines all around 1994 Dx hatch stock |
Re: i need specs
Torque specs
Cyl Head bolts.- first step= 22 ft lbs, second step= D15Z1 & D16Z6= 53 ft lbs D15B7 & D15B8= 49 Ft lbs exaust man. to head=23 ft lbs intake man. to head= 17 ft lbs Not sure about the gaskets or timing belt though. Hope it helps
thanks
Re: i need specs
z6 for top end gaskets and t-belt and d15b7 (5th gen dx, lx) for bottom end.
Re: i need specs
thanks thats all i needed to know im gettin stuff tomarrow after school, puting it all togather and than off to find the obd1 converion and a harness for the motor (vtec or non vtec, ill just run a wire)
almost there!!!
Re: i need specs
wohoo!!! What ecu are you running? P28 or P30? Dont forget to wire the knock sensor!
Re: i need specs
<[email protected]> Shoot this guy a message, he probably have the conversion harness you need. He has a ebay store and sells the jumper harnesses, if you talk to the guy he'll give ya a pretty good deal.
