power windows keep opening
Got this interesting problem, you know on some cars, the driver side window allow you to just press down once, and the windows go down all the way. For some reason, my windows keep opening, and i have to close it manually, then 5 seconds later, it opens again. It doesn't seem to be a jam on the button or anything, and since it is moving up and down fine, probably not a mechanical problem. What part of the electronic stuff could go wrong for something like that? Should I check the fuse or?
Thanks |
Re: power windows keep opening
The switch module. It contains the electronics and the switches in the drivers door. Good Luck.
![]() Yes, I am retarded. |
do you know any links/website that has info as to what I should be looking for?
Thanks |
None with pics if that is what you want. If you remove the switch you can take it to the dealer and get a new one.
switch or wiring
Some cars have a sensor that will automatically lower the window if they encounter resistance. Simple safety feature so the window won't cut your arm off or something. Maybe it has something to do with that. Could be bad sensor or connection. Or similar problem just with the normal switch.
Re: Re: power windows keep opening
