Go Back   Automotive Forums .com Car Chat > Chevrolet > Camaro | Firebird > Camaro Discussions
Old 02-22-2005, 04:37 AM   #1
FIREburd24
Send a message via AIM to FIREburd24
Talking 72 Olds 455 swap into 75 F-Bird?
will the big block bolt patern be the same as the firebirds? also, will the new tranny (Which im not sure what it is... whatever comes with the 455 ???) be able to run the the firebird??? thanx
FIREburd24 is offline   Reply With Quote
Old 02-22-2005, 06:10 AM   #2
volkerc
volkerc's Avatar
Re: 72 Olds 455 swap into 75 F-Bird?
yes
volkerc is offline   Reply With Quote
Old 02-22-2005, 10:51 AM   #3
FIREburd24
thanx, but your positive even the current tranny in the olds will fit like it was meant to be in there?
Old 02-22-2005, 11:49 AM   #4
tuske427
Send a message via AIM to tuske427
Hi:
Unless I overlooked something, please help to provide more info.
what engine/ trans does the Firebird currently have?
As for the Olds 455- I will assume it has a th400 behind it (if I'm wrong, please advise)
As for your swap, the Olds and trans will bolt in, but it is possible you may need different motor mounts, and a different crossmember, and a different driveshaft all depending on what is in the car currently.
Buicks, Olds, and Pontiacs have what's known as a "BOP" bolt pattern. It is different form the chevrolets. This is why many of these parts will interchange.
But if you have a th350 trans in the firebird now, it is a different size transmission than the th400 and this is why the crossmember will need changing ,as well as the driveshaft. However, all of these parts should be readily available at a local junkyard, or on ebay.
Much of the wiring, etc should easily adapt.
I hope this is helpful.
tuske427 is offline   Reply With Quote
