Go Back   Automotive Forums Car Chat > Honda > Accord/TSX/Accord Hybrid
Old 02-15-2005, 06:59 PM
Suffakate Suffakate is offline
Send a message via AIM to Suffakate
How do I Get the most power outta my 91 accord engine?
NO h22 SWAP!!! i wanna keep the engine that i have in my accord.... how can i make it faster? besides all the intake, headers, exhaust? i wanna go a step further.... i know about turbo..... is there anything else some of you guys can reccomend? please help!
Old 02-15-2005, 08:54 PM
Mojeans69 Mojeans69 is offline
You can get Nitrous, that is a quick way to get some horses, you can also go N/A, with the pistons, cams, etc.
Old 02-16-2005, 12:19 AM
Re: How do I Get the most power outta my 91 accord engine?
im kinda new....whats N/A?
Old 02-16-2005, 01:32 AM
mydelsolrocks's Avatar
mydelsolrocks mydelsolrocks is offline
Send a message via AIM to mydelsolrocks
N/A stands for naturally aspirated....not F/I (forced induction) such as turbo or Super charging.
really, an easy thing wold be N2O butttt be careful. trust me....thats why i now drive an acc
overspecialize and you breed in weakness, it's slow death...
motoko kusanagi
Old 02-16-2005, 01:36 AM
hmm, wonder if id need one for my 92....that SOB shifts hard as is....and the tranny only has 75K original miles....
motoko kusanagi
Old 02-16-2005, 03:28 AM
SenseiAccord SenseiAccord is offline
cams from gude. there is another company but i forget what it was called. most accord stock motor guys get regrind from gude but some ppl say their cams break. The other company was better but i forgot. ill try repost when i remember.
u can also get MSD, iridium plugs, plug wires, grounding system, replace cat with test pipe, light weight flywheel, heavy duty pressure plate clutch, pulleys, cam gears, higher compression pistons, better sealing piston rings, 3 or 5 angle valve job, port and polish head, port and polish intake manifold, bigger throttle body (ebay sells skunk2 68mm), and of course cold air intake, header and mandrel bent exhaust... also dont forget weight reduction! that does a pretty big difference. other than that i havent seen anything else for our car like valvetrain and other hardcore internals. f22s have limited parts unlike how b-series engine have.
Old 02-16-2005, 08:50 AM
Ehscrewdude Ehscrewdude is offline
Send a message via AIM to Ehscrewdude
I agree with sensei, but instead of getting iridium stick with the NGK V-power spark plugs. Wires it really doesn't make much of a difference, but if you get anything too cheap then it'll hurt your performance, and thats bad...
Old 02-16-2005, 10:26 AM
the car is an auto...... do you guys know about how much it will cost to switch it to a manual? or is there a shift kit available?
